주요 콘텐츠로 건너뛰기
소개
This guide is to help replace a damaged battery in a Sony Vaio SVE111B11L laptop with ease.
  1. Remove the charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector. Locate the battery on the bottom of the computer.
    • Remove the charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector.
    • Locate the battery on the bottom of the computer.
    • Flip the computer so that the battery faces you.
  2. Locate the two latches with the words “lock” and “release” on them.
    • Locate the two latches with the words “lock” and “release” on them.
  3. Push the latches towards each other and lift the battery to remove it.
    • Push the latches towards each other and lift the battery to remove it.
결론
다른 4명이 해당 안내서를 완성하였습니다.
John Noll
회원 가입일: 2016년 09월 29일
777 평판
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 609
