주요 콘텐츠로 건너뛰기
Sony Vaio SVE111B11L Keyboard Assembly Replacement
필요한 것
  1. Sony Vaio SVE111B11L Keyboard Assembly Replacement, Battery: 1 단계, 이미지 1/2 Sony Vaio SVE111B11L Keyboard Assembly Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector.
    • Locate the battery on the bottom of the computer.
    • Flip the computer so that the battery faces you.
  2. Sony Vaio SVE111B11L Keyboard Assembly Replacement: 2 단계, 이미지 1/1
    • Locate the two latches with the words “lock” and “release” on them.
  3. Sony Vaio SVE111B11L Keyboard Assembly Replacement: 3 단계, 이미지 1/1
    • Push the latches towards each other and lift the battery to remove it.
  4. Sony Vaio SVE111B11L Keyboard Assembly Replacement, Keyboard Assembly: 4 단계, 이미지 1/1
    • Remove the memory door on the bottom of the computer to access the screw for the keyboard.
    • The screws for the memory door do not come out.
  5. Sony Vaio SVE111B11L Keyboard Assembly Replacement: 5 단계, 이미지 1/1
    • Remove the 6.7 mm screw that holds the keyboard assembly in place.
  6. Sony Vaio SVE111B11L Keyboard Assembly Replacement: 6 단계, 이미지 1/1
    • Be careful not to break the keyboard wire connection.
    • Slide the wires out, away from the solder connections.
    • Flip the computer over and open it.
  7. Sony Vaio SVE111B11L Keyboard Assembly Replacement: 7 단계, 이미지 1/3 Sony Vaio SVE111B11L Keyboard Assembly Replacement: 7 단계, 이미지 2/3 Sony Vaio SVE111B11L Keyboard Assembly Replacement: 7 단계, 이미지 3/3
    • Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches.
    • Using an opening tool, gently pull out and slightly up on the connector clip.
    • Gently lift the keyboard assembly up and out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
John Noll
회원 가입일: 09/29/16
819 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 11
30일 전: 17
전체 시간: 1,219
