소개
Use this guide involving the Sony Valo SVE111B11L to replace its motherboard. The motherboard is the main connection point for the whole computer. It is recommended to use the two tools provided by iFixit: the Phillips #0 screwdriver and the iFixit opening tool.
필요한 것
Locate the battery on the bottom of the computer.
Flip the computer so that the battery faces you.
Remove the memory door on the bottom of the computer to access the screw for the keyboard.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
i have the same laptop, and i mistakenly remove the mother board cmos battery , and is not recognizing my laptop system hard drive.
in this case what can i do in other to restore it back.
