주요 콘텐츠로 건너뛰기
Sony Vaio SVE15112FXS Fan Replacement
필요한 것
  1. Sony Vaio SVE15112FXS Fan Replacement, Fan: 1 단계, 이미지 1/1
    • Power laptop off before beginning.
    • Turn the laptop over so that it is positioned top down with the model number facing you.
  2. Sony Vaio SVE15112FXS Fan Replacement: 2 단계, 이미지 1/1
    • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws securing the hard drive cover.
    • To avoid losing any parts, we recommend that you place the loose screws on a magnetic project mat.
  3. Sony Vaio SVE15112FXS Fan Replacement: 3 단계, 이미지 1/2 Sony Vaio SVE15112FXS Fan Replacement: 3 단계, 이미지 2/2
    • To expose the hard drive, remove the cover by sliding it toward you and pulling up on the panel.
  4. Sony Vaio SVE15112FXS Fan Replacement: 4 단계, 이미지 1/1
    • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws attaching the hard drive to the laptop.
  5. Sony Vaio SVE15112FXS Fan Replacement: 5 단계, 이미지 1/2 Sony Vaio SVE15112FXS Fan Replacement: 5 단계, 이미지 2/2
    • Pull the clear plastic ribbon to the left until the mount is detached from the laptop.
    • There will be some resistance as the hard drive is disconnected. If it does not move at all, check that all anchor screws are removed.
    • Lift the hard drive out of the well.
  6. Sony Vaio SVE15112FXS Fan Replacement: 6 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the one 4.0 mm screw next to the model number label.
  7. Sony Vaio SVE15112FXS Fan Replacement: 7 단계, 이미지 1/1
    • Use a plastic opening tool to slide the CD-ROM out from the laptop.
  8. Sony Vaio SVE15112FXS Fan Replacement: 8 단계, 이미지 1/3 Sony Vaio SVE15112FXS Fan Replacement: 8 단계, 이미지 2/3 Sony Vaio SVE15112FXS Fan Replacement: 8 단계, 이미지 3/3
    • Slide the "lock" tab upward to unlock the battery before removal.
    • While pushing the "release" tab upward, lift the battery and pull outward to remove it from the laptop.
  9. Sony Vaio SVE15112FXS Fan Replacement: 9 단계, 이미지 1/3 Sony Vaio SVE15112FXS Fan Replacement: 9 단계, 이미지 2/3 Sony Vaio SVE15112FXS Fan Replacement: 9 단계, 이미지 3/3
    • To unsecure the bottom cover, remove all the cover screws using a #0 Phillips screwdriver.
    • Remove the two 9.0 mm screws on each side of the battery.
    • Remove the twelve 8.0 mm long screws alongside the entire back cover.
    • Remove the three 3.0 mm screws inside the battery well.
  10. Sony Vaio SVE15112FXS Fan Replacement: 10 단계, 이미지 1/3 Sony Vaio SVE15112FXS Fan Replacement: 10 단계, 이미지 2/3 Sony Vaio SVE15112FXS Fan Replacement: 10 단계, 이미지 3/3
    • Use a plastic opening tool to carefully pry open the latch points located under the silver plastic trim. Repeat this around the back cover.
    • It may be easiest to start around the CD-ROM bay because there is more room.
    • To avoid damaging the plastic trim and cover, do not force difficult areas and make sure the opening tool is completely under the black plastic cover, not just the silver trim.
    • Lift the back cover upward and away from the laptop.
  11. Sony Vaio SVE15112FXS Fan Replacement: 11 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the three 3.0 mm screws attaching the fan to the heat sink unit.
  12. Sony Vaio SVE15112FXS Fan Replacement: 12 단계, 이미지 1/2 Sony Vaio SVE15112FXS Fan Replacement: 12 단계, 이미지 2/2
    • Use a plastic opening tool to unsecure the white power cable connector.
    • Do not pull on the wires as this could rip them from the cable connector.
    • Carefully unwrap the red and yellow wires from the hooks.
    • Take note of how the wires are wrapped around the hooks.
  13. Sony Vaio SVE15112FXS Fan Replacement: 13 단계, 이미지 1/1
    • Lift the fan upward to remove it from the heat sink unit.
결론
Ashley Bierman
회원 가입일: 09/06/18
1,223 평판
안내서 5개 작성하였습니다
Ohio State, Team S1-G1, Whitney Fall 2018 Ohio State, Team S1-G1, Whitney Fall 2018 회원
OSU-WHITNEY-F18S1G1
2 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 490
