소개
If your laptop is experiencing performance or storage issues, you can use this guide to replace the internal hard drive. This process is simple, and only requires a #0 Phillips screwdriver and magnetic project mat to keep track of the screws for each step. Be sure to handle the hard drive with care during removal, and do not touch the gold contact points because dirt and debris can damage the part.
필요한 것
Turn the laptop over so that it is positioned top down with the model number facing you.
다른 한 분이 해당 안내서를 완성하였습니다.
