주요 콘텐츠로 건너뛰기
Sony Vaio SVE15112FXS Hard Drive Replacement
필요한 것
  1. Sony Vaio SVE15112FXS Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Power laptop off before beginning.
    • Turn the laptop over so that it is positioned top down with the model number facing you.
  2. Sony Vaio SVE15112FXS Hard Drive Replacement: 2 단계, 이미지 1/1
    • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws securing the hard drive cover.
    • To avoid losing any parts, we recommend that you place the loose screws on a magnetic project mat.
  3. Sony Vaio SVE15112FXS Hard Drive Replacement: 3 단계, 이미지 1/2 Sony Vaio SVE15112FXS Hard Drive Replacement: 3 단계, 이미지 2/2
    • To expose the hard drive, remove the cover by sliding it toward you and pulling up on the panel.
  4. Sony Vaio SVE15112FXS Hard Drive Replacement: 4 단계, 이미지 1/1
    • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws attaching the hard drive to the laptop.
  5. Sony Vaio SVE15112FXS Hard Drive Replacement: 5 단계, 이미지 1/2 Sony Vaio SVE15112FXS Hard Drive Replacement: 5 단계, 이미지 2/2
    • Pull the clear plastic ribbon to the left until the mount is detached from the laptop.
    • There will be some resistance as the hard drive is disconnected. If it does not move at all, check that all anchor screws are removed.
    • Lift the hard drive out of the well.
  6. Sony Vaio SVE15112FXS Hard Drive Replacement: 6 단계, 이미지 1/2 Sony Vaio SVE15112FXS Hard Drive Replacement: 6 단계, 이미지 2/2
    • Use a #0 Phillips screwdriver to remove the four 4.0 mm screws attaching the mount to the hard drive.
    • Slide the hard drive away from the mount until it is completely detached.
    • Take note of how the mount is positioned when attached to the hard drive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ashley Bierman
회원 가입일: 09/06/18
1,223 평판
안내서 5개 작성하였습니다
Ohio State, Team S1-G1, Whitney Fall 2018 Ohio State, Team S1-G1, Whitney Fall 2018 회원
OSU-WHITNEY-F18S1G1
2 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 693
