소개
If your keyboard is damaged or not working properly, you can use this guide to replace it. This process is simple and only requires a #0 Phillips screwdriver, a plastic opening tool, and magnetic project mat to keep track of the screws for each step. Be sure to handle the keyboard with care as it is a delicate part.
부품
지정된 부품이 없습니다.
Turn the laptop over so that it is positioned top down with the model number facing you.
Use a plastic opening tool to disconnect the two ZIF connectors attached to each ribbon. Both are located under the keyboard and have a clear flap that must be lifted upward before removal.
Open the white connector attached to the copper ribbon.
Open the white connected attached to the black and white striped ribbon.
Lift the keyboard away from the body of the laptop.
