이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn the laptop over so that it is positioned top down with the model number facing you.
Use a #0 Phillips screwdriver to remove the two 4.0 mm screws securing the hard drive cover.
To expose the hard drive, remove the cover by sliding it toward you and pulling up on the panel.
Use a #0 Phillips screwdriver to remove the two 4.0 mm screws attaching the hard drive to the laptop.
Pull the clear plastic ribbon to the left until the mount is detached from the laptop.
Lift the hard drive out of the well.
Use a Phillips #0 screwdriver to remove the one 4.0 mm screw next to the model number label.
Slide the "lock" tab upward to unlock the battery before removal.
While pushing the "release" tab upward, lift the battery and pull outward to remove it from the laptop.
To unsecure the back cover, remove all the case screws using a #0 Phillips screwdriver.
Remove the two 9.0 mm screws on each side of the battery.
Remove the twelve 8.0 mm long screws alongside the entire back cover.
Remove the three 3.0 mm screws inside the battery well.
Use a plastic opening tool to carefully pry open the latch points located under the silver plastic trim. Repeat this around the back cover.
Lift the back cover upward and away from the laptop.
Gently push the rectangular opening on the CD-ROM well to loosen the keyboard.
Use a plastic opening tool to pry upward on the keyboard. Only the top of the keyboard is latched.
Lift the keyboard toward you and away from the laptop.
Use a plastic opening tool to disconnect the two ZIF connectors attached to each ribbon. Both are located under the keyboard and have a clear flap that must be lifted upward before removal.
Open the white connector attached to the copper ribbon.
Open the white connected attached to the black and white striped ribbon.
Lift the keyboard away from the body of the laptop.
다른 한 분이 해당 안내서를 완성하였습니다.
