소개
If your laptop display is damaged or does not work at all, you can use this guide to replace the LCD Screen. This process is simple, and only requires a #0 Phillips screwdriver, plastic opening tool, and magnetic project mat to keep track of the screws for each step. Be sure to handle the LCD Screen and all wires with care, as they are delicate parts.
필요한 것
Turn the laptop over so that it is positioned top down with the model number facing you.
다른 한 분이 해당 안내서를 완성하였습니다.
