주요 콘텐츠로 건너뛰기
Sony Vaio SVE151G11L Speaker Replacement
필요한 것
  1. Sony Vaio SVE151G11L Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the laptop over so its underside is facing upwards and visible.
  2. Sony Vaio SVE151G11L Speaker Replacement: 2 단계, 이미지 1/1
    • Standing so that the barcode and warning labels are upright and legible, push the left tab up and away from yourself.
  3. Sony Vaio SVE151G11L Speaker Replacement: 3 단계, 이미지 1/1
    • Standing so that the barcode and warning labels are upright and legible, push the right tab up and away from yourself.
  4. Sony Vaio SVE151G11L Speaker Replacement: 4 단계, 이미지 1/1
    • Locate the small gap where the battery and the laptop shell meet. Lift from the gap and rotate the battery up and away from yourself.
  5. Sony Vaio SVE151G11L Speaker Replacement: 5 단계, 이미지 1/1
    • Pull battery away from laptop.
  6. Sony Vaio SVE151G11L Speaker Replacement, Hard Disk Drive: 6 단계, 이미지 1/1
    • Flip laptop over so the bottom is facing upwards.
  7. Sony Vaio SVE151G11L Speaker Replacement: 7 단계, 이미지 1/1
    • Remove 2 bottom screws in the top right on the HDD cover, with a size P000 screwdriver.
  8. Sony Vaio SVE151G11L Speaker Replacement: 8 단계, 이미지 1/2 Sony Vaio SVE151G11L Speaker Replacement: 8 단계, 이미지 2/2
    • Pop open the cover to the HDD.
  9. Sony Vaio SVE151G11L Speaker Replacement: 9 단계, 이미지 1/1
    • Remove the screws on the HDD with a Phillips #000 screwdriver.
  10. Sony Vaio SVE151G11L Speaker Replacement: 10 단계, 이미지 1/2 Sony Vaio SVE151G11L Speaker Replacement: 10 단계, 이미지 2/2
    • Pull plastic tab away from the laptop.
    • Lift HDD away from laptop.
  11. Sony Vaio SVE151G11L Speaker Replacement, Speakers: 11 단계, 이미지 1/3 Sony Vaio SVE151G11L Speaker Replacement, Speakers: 11 단계, 이미지 2/3 Sony Vaio SVE151G11L Speaker Replacement, Speakers: 11 단계, 이미지 3/3
    • Remove the back cover.
  12. Sony Vaio SVE151G11L Speaker Replacement: 12 단계, 이미지 1/2 Sony Vaio SVE151G11L Speaker Replacement: 12 단계, 이미지 2/2
    • Remove 4 hinge screws with a Phillips #0 screwdriver.
  13. Sony Vaio SVE151G11L Speaker Replacement: 13 단계, 이미지 1/3 Sony Vaio SVE151G11L Speaker Replacement: 13 단계, 이미지 2/3 Sony Vaio SVE151G11L Speaker Replacement: 13 단계, 이미지 3/3
    • Pop open hinge.
    • Remove black screw size P000.
  14. Sony Vaio SVE151G11L Speaker Replacement: 14 단계, 이미지 1/2 Sony Vaio SVE151G11L Speaker Replacement: 14 단계, 이미지 2/2
    • Remove wiring along its guide.
  15. Sony Vaio SVE151G11L Speaker Replacement: 15 단계, 이미지 1/3 Sony Vaio SVE151G11L Speaker Replacement: 15 단계, 이미지 2/3 Sony Vaio SVE151G11L Speaker Replacement: 15 단계, 이미지 3/3
    • Remove two hinge screws size P00.
    • Pop open hinge.
  16. Sony Vaio SVE151G11L Speaker Replacement: 16 단계, 이미지 1/2 Sony Vaio SVE151G11L Speaker Replacement: 16 단계, 이미지 2/2
    • Remove black screw.
  17. Sony Vaio SVE151G11L Speaker Replacement: 17 단계, 이미지 1/2 Sony Vaio SVE151G11L Speaker Replacement: 17 단계, 이미지 2/2
    • Remove secondary black screw.
  18. Sony Vaio SVE151G11L Speaker Replacement: 18 단계, 이미지 1/1
    • Remove speaker.
  19. Sony Vaio SVE151G11L Speaker Replacement: 19 단계, 이미지 1/2 Sony Vaio SVE151G11L Speaker Replacement: 19 단계, 이미지 2/2
    • Follow wire down its wire channel and remove it from the channel.
    • Pull up on the connector to disconnect the speakers to the motherboard.
  20. Sony Vaio SVE151G11L Speaker Replacement: 20 단계, 이미지 1/1
    • Remove speaker and wire from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alex Theg
회원 가입일: 10/15/18
758 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S9-G9, Valliere Fall 2018 UMass Dartmouth, Team S9-G9, Valliere Fall 2018 회원
UMASSD-VALLIERE-F18S9G9
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 24
전체 시간: 420
