주요 콘텐츠로 건너뛰기
Sony Vaio SVE151G11L Webcam Replacement
필요한 것
  1. Sony Vaio SVE151G11L Webcam Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the laptop over so its underside is facing upwards and visible.
  2. Sony Vaio SVE151G11L Webcam Replacement: 2 단계, 이미지 1/1
    • Standing so that the barcode and warning labels are upright and legible, push the left tab up and away from yourself.
  3. Sony Vaio SVE151G11L Webcam Replacement: 3 단계, 이미지 1/1
    • Standing so that the barcode and warning labels are upright and legible, push the right tab up and away from yourself.
  4. Sony Vaio SVE151G11L Webcam Replacement: 4 단계, 이미지 1/1
    • Locate the small gap where the battery and the laptop shell meet. Lift from the gap and rotate the battery up and away from yourself.
  5. Sony Vaio SVE151G11L Webcam Replacement: 5 단계, 이미지 1/1
    • Pull battery away from laptop.
  6. Sony Vaio SVE151G11L Webcam Replacement, Display: 6 단계, 이미지 1/1
    • Flip laptop over so the bottom is facing upwards.
    • Remove bottom of laptop.
  7. Sony Vaio SVE151G11L Webcam Replacement: 7 단계, 이미지 1/1
    • Remove antenna wires attached to the WiFi card using a plastic opening tool.
  8. Sony Vaio SVE151G11L Webcam Replacement: 8 단계, 이미지 1/1
    • Remove the other antenna wire.
  9. Sony Vaio SVE151G11L Webcam Replacement: 9 단계, 이미지 1/1
    • Remove the display cable by pulling upwards.
  10. Sony Vaio SVE151G11L Webcam Replacement: 10 단계, 이미지 1/1
    • Remove the power display cable with a plastic opening tool by pushing outwards.
  11. Sony Vaio SVE151G11L Webcam Replacement: 11 단계, 이미지 1/2 Sony Vaio SVE151G11L Webcam Replacement: 11 단계, 이미지 2/2
    • Remove 4 hinge screws with a Phillips #0 screwdriver.
  12. Sony Vaio SVE151G11L Webcam Replacement: 12 단계, 이미지 1/2 Sony Vaio SVE151G11L Webcam Replacement: 12 단계, 이미지 2/2
    • Lift upward on the hinges with a plastic opening tool to release them.
  13. Sony Vaio SVE151G11L Webcam Replacement: 13 단계, 이미지 1/1
    • Separate the bottom of the laptop from the monitor.
  14. Sony Vaio SVE151G11L Webcam Replacement: 14 단계, 이미지 1/1
    • Completely detach screen from the laptop.
  15. Sony Vaio SVE151G11L Webcam Replacement, Webcam: 15 단계, 이미지 1/1
    • Remove the rubber nipples to expose the screws using the pointed side of the spudger.
  16. Sony Vaio SVE151G11L Webcam Replacement: 16 단계, 이미지 1/1
    • Remove each of the screws revealed from the step below with a P00 screwdriver.
  17. Sony Vaio SVE151G11L Webcam Replacement: 17 단계, 이미지 1/2 Sony Vaio SVE151G11L Webcam Replacement: 17 단계, 이미지 2/2
    • Pop open display housing and follow the plastic to remove the screen.
  18. Sony Vaio SVE151G11L Webcam Replacement: 18 단계, 이미지 1/2 Sony Vaio SVE151G11L Webcam Replacement: 18 단계, 이미지 2/2
    • Remove the camera cable with the spudger.
  19. Sony Vaio SVE151G11L Webcam Replacement: 19 단계, 이미지 1/1
    • Remove screws on both sides using a P000 screwdriver.
  20. Sony Vaio SVE151G11L Webcam Replacement: 20 단계, 이미지 1/1
    • Pop out the board using a spudger.
  21. Sony Vaio SVE151G11L Webcam Replacement: 21 단계, 이미지 1/1
    • The board is now removed.
결론
Azka Khanani
회원 가입일: 10/17/18
313 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S9-G9, Valliere Fall 2018 UMass Dartmouth, Team S9-G9, Valliere Fall 2018 회원
UMASSD-VALLIERE-F18S9G9
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 19
전체 시간: 1,058
