주요 콘텐츠로 건너뛰기
Sony Vaio SVE171C11L Motherboard Replacement
필요한 것
  1. Sony Vaio SVE171C11L Motherboard Replacement, Motherboard: 1 단계, 이미지 1/2 Sony Vaio SVE171C11L Motherboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Turn the laptop facedown.
    • Locate the battery compartment at the top of the laptop base. You will see two tabs on it.
    • Push the two tabs up to release the battery. Set it aside.
  2. Sony Vaio SVE171C11L Motherboard Replacement: 2 단계, 이미지 1/2 Sony Vaio SVE171C11L Motherboard Replacement: 2 단계, 이미지 2/2
    • Rotate the laptop so the empty battery compartment is now at the bottom.
    • Remove the two screws that secure the hard drive cover using a T5 Torx screwdriver. Set it aside.
  3. Sony Vaio SVE171C11L Motherboard Replacement: 3 단계, 이미지 1/2 Sony Vaio SVE171C11L Motherboard Replacement: 3 단계, 이미지 2/2
    • Remove the three screws securing the hard drive disk in place.
    • Use the blue ribbon attached to the hard drive disk to carefully remove it from laptop. Set it aside.
  4. Sony Vaio SVE171C11L Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove all screws holding the back panel from the laptop.
    • Carefully pull up the back panel to remove it.
  5. Sony Vaio SVE171C11L Motherboard Replacement: 5 단계, 이미지 1/3 Sony Vaio SVE171C11L Motherboard Replacement: 5 단계, 이미지 2/3 Sony Vaio SVE171C11L Motherboard Replacement: 5 단계, 이미지 3/3
    • Remove the cables from the fan and unscrew the heatsink.
    • The heatsink has many metal pieces jutting out from its base and is located under the fan.
    • Carefully disconnect the tabs on the edges of the motherboard.
    • Unscrew the screws holding the motherboard in place. Set them aside.
    • On the underside of the motherboard, disconnect the keyboard from the motherboard.
    • Once ALL cables are disconnected, carefully remove the motherboard.
결론
Edward Briseno
회원 가입일: 09/26/22
893 평판
안내서 6개 작성하였습니다
CSU Los Angeles, Team 6-3, Adachi Fall 2022 CSU Los Angeles, Team 6-3, Adachi Fall 2022 회원
CSULA-ADACHI-F22S6G3
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 30
전체 시간: 364
