주요 콘텐츠로 건너뛰기
Sony Vaio SVE171C11L Speaker Replacement
필요한 것
  1. Sony Vaio SVE171C11L Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the laptop over so its underside is facing upwards and visible.
  2. Sony Vaio SVE171C11L Speaker Replacement: 2 단계, 이미지 1/1
    • Once you flip the laptop over, make sure the right tab is pushed upwards to unlock it.
    • Use your left hand to push up the left tab to release the battery.
  3. Sony Vaio SVE171C11L Speaker Replacement: 3 단계, 이미지 1/1
    • After the battery is released, locate the small gap where the battery and the shell meet. Then lift the gap up and rotate the battery up and away from yourself.
  4. Sony Vaio SVE171C11L Speaker Replacement: 4 단계, 이미지 1/1
    • Pull the battery away.
  5. Sony Vaio SVE171C11L Speaker Replacement, Hard Drive: 5 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the two screws that secure the hard drive cover.
  6. Sony Vaio SVE171C11L Speaker Replacement: 6 단계, 이미지 1/2 Sony Vaio SVE171C11L Speaker Replacement: 6 단계, 이미지 2/2
    • After the screw have been removed, pop the hard drive cover open.
  7. Sony Vaio SVE171C11L Speaker Replacement: 7 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the 3 screws that secure the hard drive.
  8. Sony Vaio SVE171C11L Speaker Replacement: 8 단계, 이미지 1/1
    • When finished removing the screws, use your fingers to hold the blue ribbon attached from the hard drive to remove it from laptop
  9. Sony Vaio SVE171C11L Speaker Replacement, Speaker: 9 단계, 이미지 1/2 Sony Vaio SVE171C11L Speaker Replacement, Speaker: 9 단계, 이미지 2/2
    • Remove the eleven 3mm flathead screws that surround the back panel.
    • Remove the back cover.
  10. Sony Vaio SVE171C11L Speaker Replacement: 10 단계, 이미지 1/1
    • On the left speaker, unplug the cable that is in the way so you can remove the left speaker safely.
  11. Sony Vaio SVE171C11L Speaker Replacement: 11 단계, 이미지 1/1
    • Remove the single screw at the bottom of the speaker
  12. Sony Vaio SVE171C11L Speaker Replacement: 12 단계, 이미지 1/1
    • Remove the 2 black scews that at the top of the speaker.
  13. Sony Vaio SVE171C11L Speaker Replacement: 13 단계, 이미지 1/2 Sony Vaio SVE171C11L Speaker Replacement: 13 단계, 이미지 2/2
    • Carefully remove the speaker. Keep watch no wiring is in the way.
    • Do this to both sides to remove the second speaker.
결론
Edward Briseno
회원 가입일: 09/26/22
893 평판
안내서 6개 작성하였습니다
CSU Los Angeles, Team 6-3, Adachi Fall 2022 CSU Los Angeles, Team 6-3, Adachi Fall 2022 회원
CSULA-ADACHI-F22S6G3
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 117
