소개
This guide helps users to remove the back panel, which is required to access the other pieces of the laptop and is the first step to any part replacement.
필요한 것
Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
거의 끝나갑니다!
결론
