주요 콘텐츠로 건너뛰기
Sony Vaio SVF15A16CXB Fan Replacement
필요한 것
  1. Sony Vaio SVF15A16CXB Fan  Replacement, Back Panel: 1 단계, 이미지 1/1
    • Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • 6 mm screws marked in red, 4 mm marked in orange
  2. Sony Vaio SVF15A16CXB Fan  Replacement: 2 단계, 이미지 1/2 Sony Vaio SVF15A16CXB Fan  Replacement: 2 단계, 이미지 2/2
    • Using a plastic opening tool, pull the optical drive out of the computer by the seam.
    • In reassembly, slide the optical drive back in after reapplying cover.
  3. Sony Vaio SVF15A16CXB Fan  Replacement: 3 단계, 이미지 1/1
    • Run the opening tool along the bottom cover seam.
  4. Sony Vaio SVF15A16CXB Fan  Replacement: 4 단계, 이미지 1/1
    • Lift the clip marked in red in order to release the back cover.
    • Lift the back cover.
  5. Sony Vaio SVF15A16CXB Fan  Replacement, Fan: 5 단계, 이미지 1/1
    • Unplug the clip (red black yellow wires) by pulling it in an upward direction.
  6. Sony Vaio SVF15A16CXB Fan  Replacement: 6 단계, 이미지 1/1
    • Remove two 4mm screws on the left side of the circular fan.
    • Both of these screws have a white washer attached.
  7. Sony Vaio SVF15A16CXB Fan  Replacement: 7 단계, 이미지 1/1
    • Unscrew the four 4mm screws from the connecting copper piece. The two screws are located on either side of the copper piece.
    • The 4 mm screws won’t come out but the fan will, the screws are just to hold the fan in place.
  8. Sony Vaio SVF15A16CXB Fan  Replacement: 8 단계, 이미지 1/2 Sony Vaio SVF15A16CXB Fan  Replacement: 8 단계, 이미지 2/2
    • Gently pull off the fan from the motherboard.
결론
qiuhong Li
회원 가입일: 10/04/18
109 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 10
전체 시간: 502
