주요 콘텐츠로 건너뛰기
Sony Vaio SVF15A16CXB RAM Replacement
필요한 것
  1. Sony Vaio SVF15A16CXB RAM Replacement, Back Panel: 1 단계, 이미지 1/1
    • Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • 6 mm screws marked in red, 4 mm marked in orange
  2. Sony Vaio SVF15A16CXB RAM Replacement: 2 단계, 이미지 1/2 Sony Vaio SVF15A16CXB RAM Replacement: 2 단계, 이미지 2/2
    • Using a plastic opening tool, pull the optical drive out of the computer by the seam.
    • In reassembly, slide the optical drive back in after reapplying cover.
  3. Sony Vaio SVF15A16CXB RAM Replacement: 3 단계, 이미지 1/1
    • Run the opening tool along the bottom cover seam.
  4. Sony Vaio SVF15A16CXB RAM Replacement: 4 단계, 이미지 1/1
    • Lift the clip marked in red in order to release the back cover.
    • Lift the back cover.
  5. Sony Vaio SVF15A16CXB RAM Replacement, RAM: 5 단계, 이미지 1/1
    • Locate the two metal clips securing the RAM.
  6. Sony Vaio SVF15A16CXB RAM Replacement: 6 단계, 이미지 1/1
    • Pull apart the two metal clips with your fingers.
    • Once you pull the metal clips away, the RAM will spring up from its original position.
  7. Sony Vaio SVF15A16CXB RAM Replacement: 7 단계, 이미지 1/1
    • Pull the RAM out of the laptop.
결론
Irven Coulter
회원 가입일: 10/04/18
258 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 675
