주요 콘텐츠로 건너뛰기
Sony Vaio SVF15N17CXB Hard Drive Replacement
필요한 것
  1. Sony Vaio SVF15N17CXB Hard Drive Replacement, Back Panel: 1 단계, 이미지 1/1
    • Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • 6 mm screws marked in red, 4 mm marked in orange
  2. Sony Vaio SVF15N17CXB Hard Drive Replacement: 2 단계, 이미지 1/2 Sony Vaio SVF15N17CXB Hard Drive Replacement: 2 단계, 이미지 2/2
    • Using a plastic opening tool, pull the optical drive out of the computer by the seam.
    • In reassembly, slide the optical drive back in after reapplying cover.
  3. Sony Vaio SVF15N17CXB Hard Drive Replacement: 3 단계, 이미지 1/1
    • Run the opening tool along the bottom cover seam.
  4. Sony Vaio SVF15N17CXB Hard Drive Replacement: 4 단계, 이미지 1/1
    • Lift the clip marked in red in order to release the back cover.
    • Lift the back cover.
  5. Sony Vaio SVF15N17CXB Hard Drive Replacement, Hard Drive: 5 단계, 이미지 1/1
    • Unscrew the three 4mm screws with the Phillips #0 screwdriver located on the outer edge of the hard drive.
  6. Sony Vaio SVF15N17CXB Hard Drive Replacement: 6 단계, 이미지 1/1
    • Lift hard drive up from it groundings.
    • Slide hard drive to the left in order to remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Quinn Walter
회원 가입일: 10/04/18
311 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 7
전체 시간: 1,124
