필요한 것
Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
Unscrew the three 4mm screws with the Phillips #0 screwdriver located on the outer edge of the hard drive.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
