주요 콘텐츠로 건너뛰기
Sony Vaio SVT151A11L Back Panel Replacement
필요한 것
  1. Sony Vaio SVT151A11L Back Panel Replacement, Battery: 1 단계, 이미지 1/2 Sony Vaio SVT151A11L Back Panel Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the laptop over so that the battery on the underside of the device is revealed.
    • Unscrew the two 11mm slotted silver screws that can be found at the top of the battery.
  2. Sony Vaio SVT151A11L Back Panel Replacement: 2 단계, 이미지 1/3 Sony Vaio SVT151A11L Back Panel Replacement: 2 단계, 이미지 2/3 Sony Vaio SVT151A11L Back Panel Replacement: 2 단계, 이미지 3/3
    • Wedge the plastic opening tool between the back panel and the battery on the top left side of the device.
    • Push down on the plastic opening tool until the battery lifts from the back of the laptop.
    • Grab the battery and remove it from the device.
  3. Sony Vaio SVT151A11L Back Panel Replacement, Back Panel: 3 단계, 이미지 1/3 Sony Vaio SVT151A11L Back Panel Replacement, Back Panel: 3 단계, 이미지 2/3 Sony Vaio SVT151A11L Back Panel Replacement, Back Panel: 3 단계, 이미지 3/3
    • Unscrew the three 4mm screws using a JIS #0 screwdriver.
    • Unscrew the eight 7 mm screws using a JIS #0 screwdriver.
    • Grab and lift the edge of the panel to pull it free from the rest of the computer.
  4. Sony Vaio SVT151A11L Back Panel Replacement: 4 단계, 이미지 1/3 Sony Vaio SVT151A11L Back Panel Replacement: 4 단계, 이미지 2/3 Sony Vaio SVT151A11L Back Panel Replacement: 4 단계, 이미지 3/3
    • Grab the disk drive located at the edge of the computer and pull it it out.
    • Unscrew the three 7 mm screws with a JIS #0 screwdriver.
결론
Nathan McGarvey
회원 가입일: 10/20/17
481 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S4-G6, Julie Fall 2017 UMass Dartmouth, Team S4-G6, Julie Fall 2017 회원
UMASSD-JULIE-F17S4G6
2 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 14
전체 시간: 1,140
