주요 콘텐츠로 건너뛰기
Sony Vaio SVT151A11L Battery Replacement
필요한 것
  1. Sony Vaio SVT151A11L Battery Replacement, Battery: 1 단계, 이미지 1/2 Sony Vaio SVT151A11L Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the laptop over so that the battery on the underside of the device is revealed.
    • Unscrew the two 11mm slotted silver screws that can be found at the top of the battery.
  2. Sony Vaio SVT151A11L Battery Replacement: 2 단계, 이미지 1/3 Sony Vaio SVT151A11L Battery Replacement: 2 단계, 이미지 2/3 Sony Vaio SVT151A11L Battery Replacement: 2 단계, 이미지 3/3
    • Wedge the plastic opening tool between the back panel and the battery on the top left side of the device.
    • Push down on the plastic opening tool until the battery lifts from the back of the laptop.
    • Grab the battery and remove it from the device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Nathan McGarvey
회원 가입일: 10/20/17
481 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S4-G6, Julie Fall 2017 UMass Dartmouth, Team S4-G6, Julie Fall 2017 회원
UMASSD-JULIE-F17S4G6
2 회원들
안내서 12개 작성하였습니다
댓글 4개
Just got the new Sony Vaio SVT151A11L Battery VGP-BPS33 Li-ion, 11.4V, 3760mAh, 43W,Silver , looks in good condition and similar as original. fix it in laptop and works well up to now. one more thing, it costs less than my thought.
julie - 답글
what size screws and thread type are used for battery mount. i have lost mine
John Sears - 답글
My computer battery is not contacted what i can do for this problem
Matiullah - 답글
SVT151A11L
SVT15112CXS
Laptop computer
Battery not connected
What i can do
Matiullah - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 32
전체 시간: 3,429
