주요 콘텐츠로 건너뛰기
Sony Vaio Tap 11 Solid State Disk Replacement
필요한 것
  1. Sony Vaio Tap 11 Solid State Disk Replacement, Screen Assembly: 1 단계, 이미지 1/1
    • Begin by opening the HDMI/USB port cover on the left edge.
    • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
  2. Sony Vaio Tap 11 Solid State Disk Replacement: 2 단계, 이미지 1/1
    • Locate and open the Micro SD slot on the top side of the device.
    • Remove the two screws located beneath the cover.
  3. Sony Vaio Tap 11 Solid State Disk Replacement: 3 단계, 이미지 1/2 Sony Vaio Tap 11 Solid State Disk Replacement: 3 단계, 이미지 2/2
    • Attach the suction cup to the top right area of the screen.
    • Pull to separate the screen from the rest of the device.
    • Be aware of the front camera cable that is still connected to the rest of the device.
    • Detach the display ribbon cable.
  4. Sony Vaio Tap 11 Solid State Disk Replacement, Solid State Disk: 4 단계, 이미지 1/1
    • Unplug the battery connector located beside the fan.
    • Locate the SSD on the right side of the device, above the battery and beneath the WiFi chip.
  5. Sony Vaio Tap 11 Solid State Disk Replacement: 5 단계, 이미지 1/1
    • Remove the two 3 mm Phillips #000 screws from the right edge of the SSD.
  6. Sony Vaio Tap 11 Solid State Disk Replacement: 6 단계, 이미지 1/2 Sony Vaio Tap 11 Solid State Disk Replacement: 6 단계, 이미지 2/2
    • Pull the SSD towards the right and slightly up, removing it from the back assembly.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Alexander Bridges
회원 가입일: 09/16/15
1,217 평판
안내서 7개 작성하였습니다
IUPUI, Team 1-2, Harley Fall 2015 IUPUI, Team 1-2, Harley Fall 2015 회원
IUPUI-HARLEY-F15S1G2
4 회원들
안내서 20개 작성하였습니다
댓글 3개
What kind of M2 Type? SSD is needed for replacement/upgrade?
Marius - 답글
OK, found the answer, it's mSATA, like the Samsung 840 EVO Series:
http://www.samsung.com/us/business/suppo...
Marius -
I did the same without pulling out the battery jack. As i tried to turn the tablet on it didn’t work. Even the fan stopped working. I inserted the power cable but no response .. nothing at all ! Please help!
ib_1990_ib - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 16
30일 전: 41
전체 시간: 5,990
