주요 콘텐츠로 건너뛰기
Sony Vaio Tap 21 SVT212A11L Battery Replacement
필요한 것
  1. Sony Vaio Tap 21 SVT212A11L Battery Replacement, Screen: 1 단계, 이미지 1/2 Sony Vaio Tap 21 SVT212A11L Battery Replacement, Screen: 1 단계, 이미지 2/2
    • Insert the plastic opening tool at an angle into the grill and lift the tab by applying force down and to the left as you are lifting it out of place.
    • Use your plastic opening tool to remove the right plastic tab blocking the screw mounts behind the device.
    • The plastic tab is located on a plastic stretch of grill running along the upper half of the back of the device.
    • You can find the tab looking for a solid fill within the grill. The tab is solid within the slits.
  2. Sony Vaio Tap 21 SVT212A11L Battery Replacement: 2 단계, 이미지 1/2 Sony Vaio Tap 21 SVT212A11L Battery Replacement: 2 단계, 이미지 2/2
  3. Sony Vaio Tap 21 SVT212A11L Battery Replacement: 3 단계, 이미지 1/3 Sony Vaio Tap 21 SVT212A11L Battery Replacement: 3 단계, 이미지 2/3 Sony Vaio Tap 21 SVT212A11L Battery Replacement: 3 단계, 이미지 3/3
    • Remove the two 5mm screws on the back of the device using a JIS 0 screwdriver.
  4. Sony Vaio Tap 21 SVT212A11L Battery Replacement: 4 단계, 이미지 1/3 Sony Vaio Tap 21 SVT212A11L Battery Replacement: 4 단계, 이미지 2/3 Sony Vaio Tap 21 SVT212A11L Battery Replacement: 4 단계, 이미지 3/3
    • Face the screen of the device upwards.
    • Gently un-clip the screen around the four sides of the body with the plastic opening tool.
    • Use an up-down motion.
    • It would be easier to do this if the device is fully rested flat by pushing the device down. It should rest on the stand.
  5. Sony Vaio Tap 21 SVT212A11L Battery Replacement: 5 단계, 이미지 1/3 Sony Vaio Tap 21 SVT212A11L Battery Replacement: 5 단계, 이미지 2/3 Sony Vaio Tap 21 SVT212A11L Battery Replacement: 5 단계, 이미지 3/3
    • Lift the screen gently from the top of the device.
    • Make sure to lift the screen from the same side the screws were removed.
  6. Sony Vaio Tap 21 SVT212A11L Battery Replacement: 6 단계, 이미지 1/1
    • Slowly and gently lay the screen on its face.
    • It's important that the cables are not damaged while doing this process. Ensure as you lay the screen on its face any cables are carefully moved insuring no stress is applied on the cables.
  7. Sony Vaio Tap 21 SVT212A11L Battery Replacement, Battery: 7 단계, 이미지 1/2 Sony Vaio Tap 21 SVT212A11L Battery Replacement, Battery: 7 단계, 이미지 2/2
    • Remove a total of four 10mm screws around the battery using a JIS 0 screwdriver.
  8. Sony Vaio Tap 21 SVT212A11L Battery Replacement: 8 단계, 이미지 1/2 Sony Vaio Tap 21 SVT212A11L Battery Replacement: 8 단계, 이미지 2/2
    • Gently remove the battery by lifting from the bottom up.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Mauricio Retana
회원 가입일: 10/02/17
742 평판
안내서 6개 작성하였습니다
Cal Poly, Team S4-G4, Livingston Fall 2017 Cal Poly, Team S4-G4, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S4G4
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 25
전체 시간: 2,141
