주요 콘텐츠로 건너뛰기
Sony Vaio Tap 21 SVT212A11L Hard Drive Replacement
필요한 것
  1. Sony Vaio Tap 21 SVT212A11L Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Locate the hard drive.
  2. Sony Vaio Tap 21 SVT212A11L Hard Drive Replacement: 2 단계, 이미지 1/2 Sony Vaio Tap 21 SVT212A11L Hard Drive Replacement: 2 단계, 이미지 2/2
    • Locate the 13mm screws for the hard drive and use the JIS 0 screwdriver to unscrew.
  3. Sony Vaio Tap 21 SVT212A11L Hard Drive Replacement: 3 단계, 이미지 1/3 Sony Vaio Tap 21 SVT212A11L Hard Drive Replacement: 3 단계, 이미지 2/3 Sony Vaio Tap 21 SVT212A11L Hard Drive Replacement: 3 단계, 이미지 3/3
    • Gently lift the hard drive upwards.
    • Ensure you have a gentle hold on the hard drive cable.
    • Gently pull the cable from the base where the cable header meets the hard drive.
    • To ensure no damage is done on the cable header, pull the header gently from both sides at the same time or gently from the center.
  4. Sony Vaio Tap 21 SVT212A11L Hard Drive Replacement: 4 단계, 이미지 1/2 Sony Vaio Tap 21 SVT212A11L Hard Drive Replacement: 4 단계, 이미지 2/2
    • Locate the screws.
    • Using the JIS 0 screwdriver, unscrew the 4mm screws.
    • Gently lift the frame after screws have been taken out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Mauricio Retana
회원 가입일: 10/02/17
763 평판
안내서 6개 작성하였습니다
Cal Poly, Team S4-G4, Livingston Fall 2017 Cal Poly, Team S4-G4, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S4G4
4 회원들
안내서 12개 작성하였습니다
댓글 12개
Is that a M.2 SSD Slot on the motherboard?
tedsoldier - 답글
Nope, that’s an mPCIE/mSATA slot, not an m.2 slot. Look at the retention screw position: m.2 uses a centre screw, mPCIE/mSATA uses a corner screw.
Spencer Martin Navarra Chew -
Yes, there is an M.2 SSD slot on the left side of the motherboard. I’ve installed a 256GB SSD in the slot on my VT21
Bill Scharf - 답글
No, it’s clearly an mPCIE/mSATA slot, not m.2. The pin/notch configuration and retention screw position make it easy to identify.
You must be using a mPCIE or mSATA SSD.
Spencer Martin Navarra Chew is correct about this slot. My mistake.
Bill Scharf -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 50
전체 시간: 5,373
