소개
Use this guide to replace the LCD panel and the screen on a Sony Vaio Tap 21 all-in-one desktop. The screen and LCD panel are attached together. It is moderately easy fix that will make your desktop look brand new.
필요한 것
Insert the plastic opening tool at an angle into the grill and lift the tab by applying force down and to the left as you are lifting it out of place.
Use your plastic opening tool to remove the right plastic tab blocking the screw mounts behind the device.
The plastic tab is located on a plastic stretch of grill running along the upper half of the back of the device.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 4개
Where can I find a replacement screen for one of these Ive looked all over online
Bill have you found a replacement screen? I just cracker mine. It still works, but would like to replace. Love this computer.
The title should be how to open Sony Vaio Tap 21 SVT212A11L and not how to replace screen
