주요 콘텐츠로 건너뛰기
Sony Vaio VGN-FS640 Fan Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Sony Vaio VGN-FS640 Fan Replacement, Backplate: 1 단계, 이미지 1/1
    • Turn off the laptop and disconnect any charging cables.
    • Flip the laptop over so that the Service Tag is shown at the top left corner.
  2. Sony Vaio VGN-FS640 Fan Replacement: 2 단계, 이미지 1/1
    • Remove the highlighted screws from the back of the laptop with a Phillips #0 Screwdriver.
  3. Sony Vaio VGN-FS640 Fan Replacement: 3 단계, 이미지 1/1
    • Remove the highlighted screws from the panels in the bottom right-hand corner of the laptop using the Phillips #0 Screwdriver.
  4. Sony Vaio VGN-FS640 Fan Replacement: 4 단계, 이미지 1/1
    • Remove the two panels in the bottom right-hand corner by sliding in the direction of the arrows imprinted on the panels.
  5. Sony Vaio VGN-FS640 Fan Replacement: 5 단계, 이미지 1/1
    • Remove the highlighted screws underneath the removed panels using the Phillips #0 Screwdriver.
  6. Sony Vaio VGN-FS640 Fan Replacement: 6 단계, 이미지 1/1
    • Carefully remove the hard drive from the panel in the bottom right-hand corner of the laptop.
  7. Sony Vaio VGN-FS640 Fan Replacement: 7 단계, 이미지 1/1
    • Locate the battery, located on the top side of the laptop to the right of the Service Tag .
    • Remove the battery by pressing inwards on the tabs on either side of the battery.
  8. Sony Vaio VGN-FS640 Fan Replacement: 8 단계, 이미지 1/1
    • Remove cover in the top left side of the laptop next to the battery by pulling it outwards.
  9. Sony Vaio VGN-FS640 Fan Replacement: 9 단계, 이미지 1/1
    • Remove the backplate of the laptop by pulling it away from the laptop.
  10. Sony Vaio VGN-FS640 Fan Replacement, Fan: 10 단계, 이미지 1/3 Sony Vaio VGN-FS640 Fan Replacement, Fan: 10 단계, 이미지 2/3 Sony Vaio VGN-FS640 Fan Replacement, Fan: 10 단계, 이미지 3/3
    • Gently remove the connector for the wire running over the fan by lifting the tab on top up with your fingernail and sliding it out.
  11. Sony Vaio VGN-FS640 Fan Replacement: 11 단계, 이미지 1/2 Sony Vaio VGN-FS640 Fan Replacement: 11 단계, 이미지 2/2
    • Remove the four screws securing the fan.
  12. Sony Vaio VGN-FS640 Fan Replacement: 12 단계, 이미지 1/2 Sony Vaio VGN-FS640 Fan Replacement: 12 단계, 이미지 2/2
    • Gently lift out the fan.
    • Do not forcefully pull the fan away. This may damage the circuit board.
  13. Sony Vaio VGN-FS640 Fan Replacement: 13 단계, 이미지 1/2 Sony Vaio VGN-FS640 Fan Replacement: 13 단계, 이미지 2/2
    • Gently disconnect the remaining wire connecting the fan to the circuit board.
    • Remove the fan from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Geoffrey
회원 가입일: 03/28/14
252 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 2-6, Vijaybhaskar Spring 2014 UMass Dartmouth, Team 2-6, Vijaybhaskar Spring 2014 회원
UMASSD-VIJAYBHASKAR-S14S2G6
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 11
전체 시간: 542
