주요 콘텐츠로 건너뛰기
Sony Vaio VGN-FS640 Hard Drive Replacement
필요한 것
  1. Sony Vaio VGN-FS640 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Lay the closed laptop on its screen so the bottom is facing towards you.
  2. Sony Vaio VGN-FS640 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Push both latches towards the center of the battery.
  3. Sony Vaio VGN-FS640 Hard Drive Replacement: 3 단계, 이미지 1/2 Sony Vaio VGN-FS640 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Revome the battery by pushing it away from the laptop.
    • Set the battery away from the laptop.
  4. Sony Vaio VGN-FS640 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/3 Sony Vaio VGN-FS640 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2/3 Sony Vaio VGN-FS640 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 3/3
    • Locate and remove the screw (Length: 7.7mm) for the hard drive cover.
    • Slide the cover until it is free from the laptop case.
    • Lift the cover to remove.
  5. Sony Vaio VGN-FS640 Hard Drive Replacement: 5 단계, 이미지 1/3 Sony Vaio VGN-FS640 Hard Drive Replacement: 5 단계, 이미지 2/3 Sony Vaio VGN-FS640 Hard Drive Replacement: 5 단계, 이미지 3/3
    • Locate and remove the four screws (Length: 7.7mm) holding the Hard Drive tray in place.
    • Using the tab on the tray, slide the Hard Drive away from the main body of the laptop.
    • The Hard Drive should now be disconnected.
    • Lift the drive out with the tab on the tray.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Matt McCarty
회원 가입일: 04/15/10
220 평판
안내서 2개 작성하였습니다
Cal Poly, Team 24-32, Regan Spring 2010 Cal Poly, Team 24-32, Regan Spring 2010 회원
CPSU-REGAN-S10S24G32
4 회원들
안내서 16개 작성하였습니다
댓글 한 개
cant sign to recover my external hard drive
manivanan88 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 13
전체 시간: 10,577
