주요 콘텐츠로 건너뛰기
Sony Vaio VGN-NW240F (PCG-7184L) Back Panel Removal
필요한 것
  1. Sony Vaio VGN-NW240F (PCG-7184L) Back Panel Removal, Battery: 1 단계, 이미지 1/1
    • Power off the laptop.
    • Unplug the charging cable and any other cables plugged into the laptop.
    • Failure to remove or unplug any cables could result in electric shock.
    • Turn the laptop over so that the back panel is facing upwards.
  2. Sony Vaio VGN-NW240F (PCG-7184L) Back Panel Removal: 2 단계, 이미지 1/1
    • Locate two switches above the battery that lock it into place.
    • Push the left-hand switch, that says "lock" above it, so that it is unlocked.
  3. Sony Vaio VGN-NW240F (PCG-7184L) Back Panel Removal: 3 단계, 이미지 1/1
    • Push and hold the right-hand switch, which says "release" above it, and lift the battery up out of its place.
  4. Sony Vaio VGN-NW240F (PCG-7184L) Back Panel Removal, Optical Drive: 4 단계, 이미지 1/1
    • Locate and unscrew the two highlighted 8 mm Phillips #1 screws.
    • There will be three dots next to the desired screws
  5. Sony Vaio VGN-NW240F (PCG-7184L) Back Panel Removal: 5 단계, 이미지 1/1
    • Grip the cover of the optical drive and slide it out.
    • If it does not come out, do not force it. Double check to make sure the screws are entirely removed.
  6. Sony Vaio VGN-NW240F (PCG-7184L) Back Panel Removal, Back Panel: 6 단계, 이미지 1/3 Sony Vaio VGN-NW240F (PCG-7184L) Back Panel Removal, Back Panel: 6 단계, 이미지 2/3 Sony Vaio VGN-NW240F (PCG-7184L) Back Panel Removal, Back Panel: 6 단계, 이미지 3/3
    • Remove all the 8mm Phillips #1 screws on the backside of the laptop.
    • There are three 3mm and two 5.3mm screws under the battery that also need to be taken out.
    • There are three 3mm screws under the optical drives that also need to be taken out.
    • Remove the RAM panel in addition to the other screws. For further instructions, refer to the RAM replacement guide.
  7. Sony Vaio VGN-NW240F (PCG-7184L) Back Panel Removal: 7 단계, 이미지 1/3 Sony Vaio VGN-NW240F (PCG-7184L) Back Panel Removal: 7 단계, 이미지 2/3 Sony Vaio VGN-NW240F (PCG-7184L) Back Panel Removal: 7 단계, 이미지 3/3
    • Pry along the edges of the back panel using the spudger.
    • If you are struggling to remove the back panel with a moderate amount of force, do NOT apply any additional force, instead double check to make sure all the screws were removed before attempting again.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Sid
회원 가입일: 05/18/14
311 평판
안내서 2개 작성하였습니다
Cal Poly, Team 9-17, Regan Spring 2014 Cal Poly, Team 9-17, Regan Spring 2014 회원
CPSU-REGAN-S14S9G17
4 회원들
안내서 18개 작성하였습니다
댓글 한 개
I put it back in the correct order but my screen won’t turn on.
zakikhimani - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 15
전체 시간: 5,490
