주요 콘텐츠로 건너뛰기
Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement
필요한 것
  1. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Power off the laptop.
    • Unplug the charging cable and any other cables plugged into the laptop.
    • Failure to remove or unplug any cables could result in electric shock.
    • Turn the laptop over so that the back panel is facing upwards.
  2. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: 2 단계, 이미지 1/1
    • Locate two switches above the battery that lock it into place.
    • Push the left-hand switch, that says "lock" above it, so that it is unlocked.
  3. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: 3 단계, 이미지 1/1
    • Push and hold the right-hand switch, which says "release" above it, and lift the battery up out of its place.
  4. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement, Back Panel: 4 단계, 이미지 1/3 Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement, Back Panel: 4 단계, 이미지 2/3 Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement, Back Panel: 4 단계, 이미지 3/3
    • Remove all the 8mm Phillips #1 screws on the backside of the laptop.
    • There are three 3mm and two 5.3mm screws under the battery that also need to be taken out.
    • There are three 3mm screws under the optical drives that also need to be taken out.
    • Remove the RAM panel in addition to the other screws. For further instructions, refer to the RAM replacement guide.
  5. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: 5 단계, 이미지 1/3 Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: 5 단계, 이미지 2/3 Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: 5 단계, 이미지 3/3
    • Pry along the edges of the back panel using the spudger.
    • If you are struggling to remove the back panel with a moderate amount of force, do NOT apply any additional force, instead double check to make sure all the screws were removed before attempting again.
  6. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement, Fan: 6 단계, 이미지 1/1
    • Locate and remove three 5.3 mm Phillips #1 screws on the bottom of the fan.
    • Locate and remove the four 5.3 mm Phillips #1 screws on the top of the fan.
  7. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: 7 단계, 이미지 1/1
    • Locate and remove the four 3mm Phillips #1 screws above the processor and attached to the bronze heat-pipes.
    • Gently lift up the fan and heatsink from the the laptop.
    • If the fan and heatsink will not lift up with ease, do NOT apply any additional force. Check again to see if all necessary screws are removed.
  8. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: 8 단계, 이미지 1/1
    • The fan attached onto the heat sink with electrical tape. Removing the electrical tape allows you to replace the fan.
  9. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement, Keyboard: 9 단계, 이미지 1/1
    • Locate the two highlighted circular openings and push the keyboard out.
    • There is a ribbon cable attaching the keyboard to the back of the motherboard. Avoid damaging the ribbon when pushing out the keyboard.
  10. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: 10 단계, 이미지 1/1
    • Detach the ribbon cable to separate the keyboard from the laptop.
    • Push open the brown clamp at the base of the ribbon to release it.
  11. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement, Motherboard: 11 단계, 이미지 1/1
    • Remove the highlighted ribbon cables from their place underneath the keyboard. To do so, lift up on the black clamps to release the cables.
  12. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: 12 단계, 이미지 1/2 Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: 12 단계, 이미지 2/2
    • Remove the highlighted 3mm Phillips #1 screws.
    • Remove the two 8mm Phillips #1 screws that are highlighted.
  13. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: 13 단계, 이미지 1/3 Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: 13 단계, 이미지 2/3 Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: 13 단계, 이미지 3/3
    • Detach all of the highlighted connectors.
    • If the connector has a plastic cable, use it to assist in removal.
    • Detach the black and grey network card cables.
  14. Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: 14 단계, 이미지 1/2 Sony Vaio VGN-NW240F (PCG-7184L) Motherboard Replacement: 14 단계, 이미지 2/2
    • Carefully lift up the motherboard from its place.
    • The USB input/output area sits within the back plate of the laptop. To ensure safe removal, lift up and pull away from the USB input panel.
    • If the motherboard does lift up or come out easily, do not apply any additional force. Check again for any unattached cables or connects before attempting again.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Kevin McGowan
회원 가입일: 04/22/14
619 평판
안내서 4개 작성하였습니다
Cal Poly, Team 9-17, Regan Spring 2014 Cal Poly, Team 9-17, Regan Spring 2014 회원
CPSU-REGAN-S14S9G17
4 회원들
안내서 18개 작성하였습니다
댓글 한 개
Excellent instructions and pics. Thank you for this guide!
stbza - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 32
전체 시간: 11,012
