주요 콘텐츠로 건너뛰기
Sony Vaio VGN-S260 Keyboard Replacement
필요한 것
  1. Sony Vaio VGN-S260 Keyboard Replacement, Battery: 1 단계, 이미지 1/3 Sony Vaio VGN-S260 Keyboard Replacement, Battery: 1 단계, 이미지 2/3 Sony Vaio VGN-S260 Keyboard Replacement, Battery: 1 단계, 이미지 3/3
    • Flip the laptop over so the Vaio logo is facing down.
    • Locate the battery at the top and Find the release and unlock slides on the battery.
    • Slide the unlock tab to the unlock position.
    • Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
  2. Sony Vaio VGN-S260 Keyboard Replacement: 2 단계, 이미지 1/2 Sony Vaio VGN-S260 Keyboard Replacement: 2 단계, 이미지 2/2
    • With the tabs still in the unlock position, slide the battery away from the main case.
  3. Sony Vaio VGN-S260 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/2 Sony Vaio VGN-S260 Keyboard Replacement, Keyboard: 3 단계, 이미지 2/2
    • Flip the computer over so the Vaio logo is facedown.
    • Unscrew the 2 screws next to the battery.
  4. Sony Vaio VGN-S260 Keyboard Replacement: 4 단계, 이미지 1/1
    • Flip the computer over again so the Vaio logo is face up.
    • Open the lid.
  5. Sony Vaio VGN-S260 Keyboard Replacement: 5 단계, 이미지 1/2 Sony Vaio VGN-S260 Keyboard Replacement: 5 단계, 이미지 2/2
    • Press down on the outer gray shell around the keyboard.
    • Use the spudger to gently lift keyboard.
    • Do not pull up the keyboard too far as it is attached to a ribbon underneath.
  6. Sony Vaio VGN-S260 Keyboard Replacement: 6 단계, 이미지 1/2 Sony Vaio VGN-S260 Keyboard Replacement: 6 단계, 이미지 2/2
    • Lift up lever underneath the ribbon to detach the keyboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jeffrey Bryan
회원 가입일: 04/20/10
570 평판
안내서 11개 작성하였습니다
Cal Poly, Team 16-4, Maness Spring 2010 Cal Poly, Team 16-4, Maness Spring 2010 회원
CPSU-MANESS-S10S16G4
4 회원들
안내서 30개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 5,477
