메인 콘텐츠로 스킵하기
소개
How to remove the upper casing of the Sony Vaio VGN-S260 laptop
부품
지정된 부품이 없습니다.
  1. Flip the laptop over so the Vaio logo is facing down. Locate the battery at the top and Find the release and unlock slides on the battery. Slide the unlock tab to the unlock position.
    • Flip the laptop over so the Vaio logo is facing down.
    • Locate the battery at the top and Find the release and unlock slides on the battery.
    • Slide the unlock tab to the unlock position.
    • Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
  2. With the tabs still in the unlock position, slide the battery away from the main case. With the tabs still in the unlock position, slide the battery away from the main case.
    • With the tabs still in the unlock position, slide the battery away from the main case.
  3. Flip the computer over so the Vaio logo is facedown. Unscrew the 2 screws next to the battery.
    • Flip the computer over so the Vaio logo is facedown.
    • Unscrew the 2 screws next to the battery.
  4. Flip the computer over again so the Vaio logo is face up.
    • Flip the computer over again so the Vaio logo is face up.
    • Open the lid.
  5. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  6. Press down on the outer gray shell around the keyboard. Use the spudger to gently lift keyboard.
    • Press down on the outer gray shell around the keyboard.
    • Use the spudger to gently lift keyboard.
    • Do not pull up the keyboard too far as it is attached to a ribbon underneath.
  7. Lift up lever underneath the ribbon to detach the keyboard. Lift up lever underneath the ribbon to detach the keyboard.
    • Lift up lever underneath the ribbon to detach the keyboard.
  8. Remove memory/wireless compartment cover.
    • Remove memory/wireless compartment cover.
  9. Flip so the Vaio Logo is face down. Locate and remove a total of 8 screws on the bottom. Locate and remove a total of 8 screws on the bottom.
    • Flip so the Vaio Logo is face down.
    • Locate and remove a total of 8 screws on the bottom.
  10. Find and remove 5 screws (they all have arrows next to them) from cover.
    • Find and remove 5 screws (they all have arrows next to them) from cover.
  11. Flip the laptop over so the Vaio logo is face up. Use the spudger to pop up the upper casing. Do not lift too much as the upper casing is attached to wires underneath.
    • Flip the laptop over so the Vaio logo is face up.
    • Use the spudger to pop up the upper casing.
    • Do not lift too much as the upper casing is attached to wires underneath.
    • Remove the wires that are attaching the upper casing to the motherboard.
  12. Remove the upper casing.
    • Remove the upper casing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jeffrey Bryan
회원 가입일: 2010년 04월 20일
552 평판
안내서 11개 작성하였습니다
Cal Poly, Team 16-4, Maness Spring 2010 Cal Poly, Team 16-4, Maness Spring 2010 회원
CPSU-MANESS-S10S16G4
4 회원들
안내서 11개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 4,491
