주요 콘텐츠로 건너뛰기
Sony Vaio VGN-SR140E Screen Replacement
필요한 것
  1. Sony Vaio VGN-SR140E Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E Screen Replacement: 2 단계, 이미지 1/1
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E Screen Replacement: 3 단계, 이미지 1/2 Sony Vaio VGN-SR140E Screen Replacement: 3 단계, 이미지 2/2
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E Screen Replacement, Screen: 4 단계, 이미지 1/3 Sony Vaio VGN-SR140E Screen Replacement, Screen: 4 단계, 이미지 2/3 Sony Vaio VGN-SR140E Screen Replacement, Screen: 4 단계, 이미지 3/3
    • Remove the rubber pads at all four corners of the screen bezel using a spudger. This will reveal four 5mm Phillips screws.
    • Use a Phillips #1 screwdriver to remove the four screws and set them aside.
  5. Sony Vaio VGN-SR140E Screen Replacement: 5 단계, 이미지 1/1
    • Remove the screen's plastic bezel. You may need to use slight pressure to release the clips that secure the bezel to the laptop.
  6. Sony Vaio VGN-SR140E Screen Replacement: 6 단계, 이미지 1/2 Sony Vaio VGN-SR140E Screen Replacement: 6 단계, 이미지 2/2
    • Lift screen bezel up and off of the laptop.
  7. Sony Vaio VGN-SR140E Screen Replacement: 7 단계, 이미지 1/3 Sony Vaio VGN-SR140E Screen Replacement: 7 단계, 이미지 2/3 Sony Vaio VGN-SR140E Screen Replacement: 7 단계, 이미지 3/3
    • Close the laptop carefully and slowly while holding the screen with your thumb to prevent it from falling.
    • Lay the screen gently on the keyboard. This will reveal the screen's connector.
  8. Sony Vaio VGN-SR140E Screen Replacement: 8 단계, 이미지 1/3 Sony Vaio VGN-SR140E Screen Replacement: 8 단계, 이미지 2/3 Sony Vaio VGN-SR140E Screen Replacement: 8 단계, 이미지 3/3
    • Grasp the connector and gently pull it out.
  9. Sony Vaio VGN-SR140E Screen Replacement: 9 단계, 이미지 1/1
    • The screen can now be removed.
결론
Jeremy
회원 가입일: 03/18/15
722 평판
안내서 4개 작성하였습니다
Michigan Tech, Team 1-6, Lauer Spring 2015 Michigan Tech, Team 1-6, Lauer Spring 2015 회원
MTU-LAUER-S15S1G6
2 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 15
전체 시간: 1,125
