주요 콘텐츠로 건너뛰기
Sony Vaio VGN-SZ120P Logic Board Replacement
필요한 것
  1. Sony Vaio VGN-SZ120P Logic Board Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Set the computer display-side down.
    • Unlock the battery by sliding the port-side latch to the 'unlock' position.
  2. Sony Vaio VGN-SZ120P Logic Board Replacement: 2 단계, 이미지 1개 중 1개
    • On the opposite side of the battery, press the release latch and slide the battery away from the main body to remove.
  3. Sony Vaio VGN-SZ120P Logic Board Replacement, Memory: 3 단계, 이미지 2개 중 1개 Sony Vaio VGN-SZ120P Logic Board Replacement, Memory: 3 단계, 이미지 2개 중 2개
    • Unscrew the two memory panel screws and set the panel aside.
    • Ignore the removal of the heatsink panel. This does not need to be removed for RAM module access.
  4. Sony Vaio VGN-SZ120P Logic Board Replacement: 4 단계, 이미지 3개 중 1개 Sony Vaio VGN-SZ120P Logic Board Replacement: 4 단계, 이미지 3개 중 2개 Sony Vaio VGN-SZ120P Logic Board Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Lift the film covering to reveal the memory module with the tweezers.
    • Pull the tabs on both sides of the RAM away from the module. The module will pop up.
    • Repeat this step for the other RAM module located directly above the memory module just removed.
  5. Sony Vaio VGN-SZ120P Logic Board Replacement, Keyboard: 5 단계, 이미지 1개 중 1개
    • Ignore the removal of the heat sink and memory panels as depicted. They do not need to be removed for the completion of this guide.
    • Remove the Torx security screw near the center of the battery-side edge.
  6. Sony Vaio VGN-SZ120P Logic Board Replacement: 6 단계, 이미지 2개 중 1개 Sony Vaio VGN-SZ120P Logic Board Replacement: 6 단계, 이미지 2개 중 2개
    • Press the tabs on each side of the display-side of the keyboard with the flat edge of a spudger.
    • Pull the keyboard toward the mouse pad and gently lift up.
  7. Sony Vaio VGN-SZ120P Logic Board Replacement: 7 단계, 이미지 2개 중 1개 Sony Vaio VGN-SZ120P Logic Board Replacement: 7 단계, 이미지 2개 중 2개
    • The keyboard is still attached by ribbon cable, don't try to remove the keyboard entirely yet.
    • Disconnect the ribbon cable by pressing the tabs on either side of the connector. Pull the cable out parallel to the connector.
    • Remove the keyboard.
  8. Sony Vaio VGN-SZ120P Logic Board Replacement, Mouse Assembly: 8 단계, 이미지 1개 중 1개
    • Turn the laptop upside down.
    • Remove the three screws from the front mouse panel located on the bottom of the laptop.
    • Carefully flip the laptop back over. Remove three more screws from the top securing the panel. A ribbon cable will still be attached to the panel when you remove it.
  9. Sony Vaio VGN-SZ120P Logic Board Replacement: 9 단계, 이미지 2개 중 1개 Sony Vaio VGN-SZ120P Logic Board Replacement: 9 단계, 이미지 2개 중 2개
    • Lift the mouse assembly just enough to access the connecting ribbon cable.
    • Lift the ribbon cable lock to remove the cable.
    • Carefully remove the mouse panel assembly and set aside.
  10. Sony Vaio VGN-SZ120P Logic Board Replacement, Hard Drive: 10 단계, 이미지 1개 중 1개
    • This is where your hard drive would be located. The replacement must be a Serial ATA(SATA) hard drive
    • Remove the four hard drive securing screws.
  11. Sony Vaio VGN-SZ120P Logic Board Replacement, Optical Drive: 11 단계, 이미지 1개 중 1개
    • Remove the securing screw on the bottom left of the optical drive.
  12. Sony Vaio VGN-SZ120P Logic Board Replacement: 12 단계, 이미지 1개 중 1개
    • Carefully slide the optical drive out right.
    • The IDE connector on the left will pop out.
  13. Sony Vaio VGN-SZ120P Logic Board Replacement, Speaker Assembly: 13 단계, 이미지 3개 중 1개 Sony Vaio VGN-SZ120P Logic Board Replacement, Speaker Assembly: 13 단계, 이미지 3개 중 2개 Sony Vaio VGN-SZ120P Logic Board Replacement, Speaker Assembly: 13 단계, 이미지 3개 중 3개
    • Remove the four screws from the underside of the computer. These screws are located underneath where the battery sits and secure the top keyboard panel.
    • To remove the panel below the screen, press up on the two tabs holding the panel in and lift up. The panel should pop off.
    • Before proceeding, remove all black tape holding down wires and other cabling.
  14. Sony Vaio VGN-SZ120P Logic Board Replacement: 14 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Pop off the antenna using a pair of tweezers.
  15. Sony Vaio VGN-SZ120P Logic Board Replacement: 15 단계, 이미지 1개 중 1개
    • Remove the seven philips screws holding the speaker assembly in place.
    • Before removing the assembly, disconnect the ribbon cable located at the top left corner of the assembly.
    • The speaker assembly will come off with the display assembly.
  16. Sony Vaio VGN-SZ120P Logic Board Replacement, screen: 16 단계, 이미지 2개 중 1개 Sony Vaio VGN-SZ120P Logic Board Replacement, screen: 16 단계, 이미지 2개 중 2개
    • Caution: Be careful of snags when pulling up assembly and speakers.
    • To remove the VGA cable, lift up on the metal bracket and gently lift the connector off the logic board.
    • To remove the webcam cable, lift up the connector from the logic board gently.
  17. Sony Vaio VGN-SZ120P Logic Board Replacement: 17 단계, 이미지 3개 중 1개 Sony Vaio VGN-SZ120P Logic Board Replacement: 17 단계, 이미지 3개 중 2개 Sony Vaio VGN-SZ120P Logic Board Replacement: 17 단계, 이미지 3개 중 3개
    • Unscrew the four securing screws, two on each side of the LCD.
    • Carefully remove the LCD. The speaker, bluetooth, and webcam assembly will come up with the display assembly.
    • Caution: Be careful of snags when pulling up display and speaker assemblies.
  18. Sony Vaio VGN-SZ120P Logic Board Replacement, Internal Fan: 18 단계, 이미지 2개 중 1개 Sony Vaio VGN-SZ120P Logic Board Replacement, Internal Fan: 18 단계, 이미지 2개 중 2개
    • Remove screws from keyboard tray
    • Remove keyboard tray
  19. Sony Vaio VGN-SZ120P Logic Board Replacement: 19 단계, 이미지 1개 중 1개
    • Caution: When removing the fan, be careful to not tear the attached ribbon cable.
    • Unscrew all five screws from the internal fan.
    • Gently remove the internal fan.
  20. Sony Vaio VGN-SZ120P Logic Board Replacement, Logic Board: 20 단계, 이미지 1개 중 1개
    • Caution: Ground yourself before removing the logic board. Static electricity can damage the logic board.
    • Unscrew and remove the logic board from the backing.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
David Hoyt
회원 가입일: 04/09/10
4,053 평판
안내서 41개를 작성함
Cal Poly, Team 25-89, Amido Spring 2010 Cal Poly, Team 25-89, Amido Spring 2010 회원
CPSU-AMIDO-S10S25G89
4 회원들
안내서 61개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 21
전체 시간: 6,790
