주요 콘텐츠로 건너뛰기
Sony Vaio VGN-SZ120P Mouse Assembly Replacement
필요한 것
  1. Sony Vaio VGN-SZ120P Mouse Assembly Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Set the computer display-side down.
    • Unlock the battery by sliding the port-side latch to the 'unlock' position.
  2. Sony Vaio VGN-SZ120P Mouse Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • On the opposite side of the battery, press the release latch and slide the battery away from the main body to remove.
  3. Sony Vaio VGN-SZ120P Mouse Assembly Replacement, Keyboard: 3 단계, 이미지 1개 중 1개
    • Ignore the removal of the heat sink and memory panels as depicted. They do not need to be removed for the completion of this guide.
    • Remove the Torx security screw near the center of the battery-side edge.
  4. Sony Vaio VGN-SZ120P Mouse Assembly Replacement: 4 단계, 이미지 2개 중 1개 Sony Vaio VGN-SZ120P Mouse Assembly Replacement: 4 단계, 이미지 2개 중 2개
    • Press the tabs on each side of the display-side of the keyboard with the flat edge of a spudger.
    • Pull the keyboard toward the mouse pad and gently lift up.
  5. Sony Vaio VGN-SZ120P Mouse Assembly Replacement: 5 단계, 이미지 2개 중 1개 Sony Vaio VGN-SZ120P Mouse Assembly Replacement: 5 단계, 이미지 2개 중 2개
    • The keyboard is still attached by ribbon cable, don't try to remove the keyboard entirely yet.
    • Disconnect the ribbon cable by pressing the tabs on either side of the connector. Pull the cable out parallel to the connector.
    • Remove the keyboard.
  6. Sony Vaio VGN-SZ120P Mouse Assembly Replacement, Mouse Assembly: 6 단계, 이미지 1개 중 1개
    • Turn the laptop upside down.
    • Remove the three screws from the front mouse panel located on the bottom of the laptop.
    • Carefully flip the laptop back over. Remove three more screws from the top securing the panel. A ribbon cable will still be attached to the panel when you remove it.
  7. Sony Vaio VGN-SZ120P Mouse Assembly Replacement: 7 단계, 이미지 2개 중 1개 Sony Vaio VGN-SZ120P Mouse Assembly Replacement: 7 단계, 이미지 2개 중 2개
    • Lift the mouse assembly just enough to access the connecting ribbon cable.
    • Lift the ribbon cable lock to remove the cable.
    • Carefully remove the mouse panel assembly and set aside.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Ashley Brooks
회원 가입일: 04/09/10
312 평판
안내서 4개를 작성함
Cal Poly, Team 25-89, Amido Spring 2010 Cal Poly, Team 25-89, Amido Spring 2010 회원
CPSU-AMIDO-S10S25G89
4 회원들
안내서 61개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 5
지난 30일: 12
전체 시간: 3,652
