주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
  1. Power off your laptop before starting.
    • Power off your laptop before starting.
    • Disconnect all external cables from the device.
  2. Flip the device over so that the battery is facing away from you.
    • Flip the device over so that the battery is facing away from you.
    • Unlock the battery by using your finger to push the "Lock" latch to the right.
    • You will hear a soft click when the latch has been disengaged.
  3. Place your finger on the "Release" latch.
    • Place your finger on the "Release" latch.
    • Slide the latch to the right and hold it.
    • Use your other hand to lift the battery from the groove.
    • Remove the battery.
  4. Remove a 5 mm Phillips #000 screw from the RAM cover located in the centre of the device.
    • Remove a 5 mm Phillips #000 screw from the RAM cover located in the centre of the device.
    • Remove the RAM cover.
    • There is no need to remove the RAMs as they won't get in the way.
  5. Remove the following eleven screws: Five 13 mm Phillips #000 screws
    • Remove the following eleven screws:
    • Five 13 mm Phillips #000 screws
    • Six 5 mm Phillips #000 screws
  6. Flip the device and open the lid so that the keyboard is facing upwards.
    • Flip the device and open the lid so that the keyboard is facing upwards.
    • Use an opening tool to lift the keyboard assembly slightly.
    • Make sure you don't lift the keyboard assembly too much as there is a ribbon cable in between.
  7. Flip the keyboard assembly towards you.
    • Flip the keyboard assembly towards you.
  8. Use an opening tool to pry the keyboard assembly connector up from its socket on the motherboard.
    • Use an opening tool to pry the keyboard assembly connector up from its socket on the motherboard.
    • Remove the keyboard assembly.
  9. Use an opening tool to pry the uSATA ribbon cable connector up from its socket on the motherboard.
    • Use an opening tool to pry the uSATA ribbon cable connector up from its socket on the motherboard.
  10. Remove two 13 mm screws from the SSD bracket using a Phillips #000 screwdriver. Remove the SSD bracket.
    • Remove two 13 mm screws from the SSD bracket using a Phillips #000 screwdriver.
    • Remove the SSD bracket.
  11. Flip the SSD bracket.
    • Flip the SSD bracket.
    • Use your hand to disconnect the uSATA connector on the right.
  12. Flip the SSD bracket.
    • Use your hand to disconnect the uSATA connector on the left.
    • Remove the uSATA ribbon cable.
  13. Remove two 2 mm Phillips #00 screws.
    • Remove two 2 mm Phillips #00 screws.
  14. Flip the SSD bracket.
  15. Take out the SSDs from the bracket.
    • Take out the SSDs from the bracket.
결론
Vincent L
회원 가입일: 2019년 01월 10일
241 평판
안내서 1개 작성함
York University, Team S3-G51, Melo-Thaiss Fall 2020 York University, Team S3-G51, Melo-Thaiss Fall 2020 회원
YORK-MELO-THAISS-F20S3G51
1 회원
안내서 1개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 64
