주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Sony Vaio VGN-Z48GD SSDs Replacement
필요한 것
  1. Sony Vaio VGN-Z48GD SSDs Replacement, SSDs: 1 단계, 이미지 1/1
    • Power off your laptop before starting.
    • Disconnect all external cables from the device.
  2. Sony Vaio VGN-Z48GD SSDs Replacement: 2 단계, 이미지 1/1
    • Flip the device over so that the battery is facing away from you.
    • Unlock the battery by using your finger to push the "Lock" latch to the right.
    • You will hear a soft click when the latch has been disengaged.
  3. Sony Vaio VGN-Z48GD SSDs Replacement: 3 단계, 이미지 1/1
    • Place your finger on the "Release" latch.
    • Slide the latch to the right and hold it.
    • Use your other hand to lift the battery from the groove.
    • Remove the battery.
  4. Sony Vaio VGN-Z48GD SSDs Replacement: 4 단계, 이미지 1/1
    • Remove a 5 mm Phillips #000 screw from the RAM cover located in the centre of the device.
    • Remove the RAM cover.
    • There is no need to remove the RAMs as they won't get in the way.
  5. Sony Vaio VGN-Z48GD SSDs Replacement: 5 단계, 이미지 1/2 Sony Vaio VGN-Z48GD SSDs Replacement: 5 단계, 이미지 2/2
    • Remove the following eleven screws:
    • Five 13 mm Phillips #000 screws
    • Six 5 mm Phillips #000 screws
  6. Sony Vaio VGN-Z48GD SSDs Replacement: 6 단계, 이미지 1/1
    • Flip the device and open the lid so that the keyboard is facing upwards.
    • Use an opening tool to lift the keyboard assembly slightly.
    • Make sure you don't lift the keyboard assembly too much as there is a ribbon cable in between.
  7. Sony Vaio VGN-Z48GD SSDs Replacement: 7 단계, 이미지 1/1
    • Flip the keyboard assembly towards you.
  8. Sony Vaio VGN-Z48GD SSDs Replacement: 8 단계, 이미지 1/1
    • Use an opening tool to pry the keyboard assembly connector up from its socket on the motherboard.
    • Remove the keyboard assembly.
  9. Sony Vaio VGN-Z48GD SSDs Replacement: 9 단계, 이미지 1/1
    • Use an opening tool to pry the uSATA ribbon cable connector up from its socket on the motherboard.
  10. Sony Vaio VGN-Z48GD SSDs Replacement: 10 단계, 이미지 1/2 Sony Vaio VGN-Z48GD SSDs Replacement: 10 단계, 이미지 2/2
    • Remove two 13 mm screws from the SSD bracket using a Phillips #000 screwdriver.
    • Remove the SSD bracket.
  11. Sony Vaio VGN-Z48GD SSDs Replacement: 11 단계, 이미지 1/1
    • Flip the SSD bracket.
    • Use your hand to disconnect the uSATA connector on the right.
  12. Sony Vaio VGN-Z48GD SSDs Replacement: 12 단계, 이미지 1/1
    • Use your hand to disconnect the uSATA connector on the left.
    • Remove the uSATA ribbon cable.
  13. Sony Vaio VGN-Z48GD SSDs Replacement: 13 단계, 이미지 1/1
    • Remove two 2 mm Phillips #00 screws.
  14. Sony Vaio VGN-Z48GD SSDs Replacement: 14 단계, 이미지 1/1
  15. Sony Vaio VGN-Z48GD SSDs Replacement: 15 단계, 이미지 1/1
    • Take out the SSDs from the bracket.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Vincent L
회원 가입일: 01/10/19
265 평판
안내서 1개 작성함
York University, Team S3-G51, Melo-Thaiss Fall 2020 York University, Team S3-G51, Melo-Thaiss Fall 2020 회원
YORK-MELO-THAISS-F20S3G51
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 13
전체 시간: 797
