주요 콘텐츠로 건너뛰기
Sony Vaio VPCCB290X Keyboard Replacement
필요한 것
  1. Sony Vaio VPCCB290X Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Attach an anti-static wrist strap to a piece of metal to prevent possible short circuiting.
    • Use a spudger to press in the black clips that lock the keyboard in place.
    • As you press in the black clips, remove the screws near the motherboard using the screwdriver.
    • Do not remove the motherboard.
  2. Sony Vaio VPCCB290X Keyboard Replacement: 2 단계, 이미지 1/1
    • Using the metal spudger, pick a corner and carefully begin to pop off the keyboard.
    • It is normal to hear a soft clicking sound as the keyboard releases from the device.
  3. Sony Vaio VPCCB290X Keyboard Replacement: 3 단계, 이미지 1/1
    • Two cables are attached to two white inserts to keep the keyboard anchored in place once the clips have been removed, and to keep the keyboard attached to the motherboard.
    • Unplug the thin cable by just simply pulling the cable straight out of the connector.
    • Leave the thicker white cable alone.
  4. Sony Vaio VPCCB290X Keyboard Replacement: 4 단계, 이미지 1/2 Sony Vaio VPCCB290X Keyboard Replacement: 4 단계, 이미지 2/2
    • To fully release the old keyboard, lift the black wedge clip by using the spudger tool to press down on the clip and release the wider cable.
결승점
Eric Martinez
회원 가입일: 02/14/17
637 평판
안내서 6개 작성하였습니다
USF Tampa, Team 20-5, Remmell Spring 2017 USF Tampa, Team 20-5, Remmell Spring 2017 회원
USFT-REMMELL-S17S20G5
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 591
