주요 콘텐츠로 건너뛰기
Sony Vaio VPCCW17FX Speakers Replacement
필요한 것
  1. Sony Vaio VPCCW17FX Speakers Replacement, Speakers: 1 단계, 이미지 1/1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Speakers Replacement: 2 단계, 이미지 1/1
    • Slide the two latches towards the center of the laptop in order to release the battery.
  3. Sony Vaio VPCCW17FX Speakers Replacement: 3 단계, 이미지 1/2 Sony Vaio VPCCW17FX Speakers Replacement: 3 단계, 이미지 2/2
    • Use fingernail or plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Speakers Replacement: 4 단계, 이미지 1/2 Sony Vaio VPCCW17FX Speakers Replacement: 4 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver to remove the two screws (Length: 7.7 mm) of the Hard Drive cover and place the cover to the side.
    • Using a Phillips #0 screwdriver, remove the one screw (Length: 7.7 mm) from the RAM cover and place it to the side.
  5. Sony Vaio VPCCW17FX Speakers Replacement: 5 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, remove all twelve screws (Length: 7.7 mm) that hold the bottom cover.
  6. Sony Vaio VPCCW17FX Speakers Replacement: 6 단계, 이미지 1/1
    • Lift and remove the back cover.
  7. Sony Vaio VPCCW17FX Speakers Replacement: 7 단계, 이미지 1/2 Sony Vaio VPCCW17FX Speakers Replacement: 7 단계, 이미지 2/2
    • Locate the fan and use a Phillips #0 screwdriver, remove the two screws (Length: 7.7 mm) that hold it in place.
    • Lift the fan and move it out of the way.
  8. Sony Vaio VPCCW17FX Speakers Replacement: 8 단계, 이미지 1/2 Sony Vaio VPCCW17FX Speakers Replacement: 8 단계, 이미지 2/2
    • Begin removing the four screws with a Phillips #0 screwdriver (Length: 7.7 mm) from the back cover.
    • Place the cover out of the way.
    • Be careful to not pull any wires out while moving the cover.
  9. Sony Vaio VPCCW17FX Speakers Replacement: 9 단계, 이미지 1/3 Sony Vaio VPCCW17FX Speakers Replacement: 9 단계, 이미지 2/3 Sony Vaio VPCCW17FX Speakers Replacement: 9 단계, 이미지 3/3
    • Using a Phillips #0 screwdriver, remove the two screws (Length: 7.7 mm) that hold the speaker in place.
    • Follow the wire until you find the ribbon cable that holds the wires and pull straight out of the connect to remove it.
    • You are now free to replace the speakers.
    • There are two speakers so be sure to repeat the same steps for the second speaker.
결론
Brianna Rukes
회원 가입일: 03/21/17
101 평판
안내서 1개 작성함
Texas Tech, Team S8-G5, Bennett Spring 2017 Texas Tech, Team S8-G5, Bennett Spring 2017 회원
TTU-BENNETT-S17S8G5
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 10
전체 시간: 482
