주요 콘텐츠로 건너뛰기
Sony Vaio VPCEB11FM Audio Card Replacement
필요한 것
  1. Sony Vaio VPCEB11FM Audio Card Replacement, Battery: 1 단계, 이미지 1/1
    • Power down and disconnect the laptop from power supply.
    • Using your fingers, unlock the tab by pushing on the slide.
  2. Sony Vaio VPCEB11FM Audio Card Replacement: 2 단계, 이미지 1/1
    • While holding the release slide, use your thumb to lift the lip of the battery to pull it out.
  3. Sony Vaio VPCEB11FM Audio Card Replacement: 3 단계, 이미지 1/1
    • Pull the battery out.
  4. Sony Vaio VPCEB11FM Audio Card Replacement, RAM: 4 단계, 이미지 1/2 Sony Vaio VPCEB11FM Audio Card Replacement, RAM: 4 단계, 이미지 2/2
    • Unscrew the RAM cover plate using the Phillips #1 Screwdriver.
    • Once the cover has been loosened, pry the cover with your finger for it to come off.
  5. Sony Vaio VPCEB11FM Audio Card Replacement: 5 단계, 이미지 1/3 Sony Vaio VPCEB11FM Audio Card Replacement: 5 단계, 이미지 2/3 Sony Vaio VPCEB11FM Audio Card Replacement: 5 단계, 이미지 3/3
    • Use your fingers to gently pull the white plastic strip outward on both sides.
    • Once you pull the strip, the strip of RAM will loosen up. Once loose the strip of RAM should lift out.
    • Once done with the top strip of RAM continue for all continuous strips.
  6. Sony Vaio VPCEB11FM Audio Card Replacement, Hard Drive: 6 단계, 이미지 1/2 Sony Vaio VPCEB11FM Audio Card Replacement, Hard Drive: 6 단계, 이미지 2/2
    • Using the Phillips #01 Screwdriver, remove the two 7mm screws.
  7. Sony Vaio VPCEB11FM Audio Card Replacement: 7 단계, 이미지 1/3 Sony Vaio VPCEB11FM Audio Card Replacement: 7 단계, 이미지 2/3 Sony Vaio VPCEB11FM Audio Card Replacement: 7 단계, 이미지 3/3
    • Use your fingers to pry the cover upward.
    • Unscrew the two 7mm screws.
    • Pull the plastic tab in the direction of the arrow to take out.
  8. Sony Vaio VPCEB11FM Audio Card Replacement: 8 단계, 이미지 1/2 Sony Vaio VPCEB11FM Audio Card Replacement: 8 단계, 이미지 2/2
    • Lift plug side first.
    • Remove all the way.
  9. Sony Vaio VPCEB11FM Audio Card Replacement: 9 단계, 이미지 1/3 Sony Vaio VPCEB11FM Audio Card Replacement: 9 단계, 이미지 2/3 Sony Vaio VPCEB11FM Audio Card Replacement: 9 단계, 이미지 3/3
    • Skip to next step if accessing other components.
    • Remove the 3mm screws with the Phillips #1 Screwdriver from hard drive bracket.
  10. Sony Vaio VPCEB11FM Audio Card Replacement, Audio Card: 10 단계, 이미지 1/3 Sony Vaio VPCEB11FM Audio Card Replacement, Audio Card: 10 단계, 이미지 2/3 Sony Vaio VPCEB11FM Audio Card Replacement, Audio Card: 10 단계, 이미지 3/3
    • #1 Unscrew the back panel
    • #2 Then work the tool around the sides to release cover. You may need a second tool to help keep your loose corner open.
  11. Sony Vaio VPCEB11FM Audio Card Replacement: 11 단계, 이미지 1/3 Sony Vaio VPCEB11FM Audio Card Replacement: 11 단계, 이미지 2/3 Sony Vaio VPCEB11FM Audio Card Replacement: 11 단계, 이미지 3/3
    • Unscrew the screw with the size of * screw driver
    • Left up the case holder
    • Gently pull the connective cable
결론
다른 3명이 해당 안내서를 완성하였습니다.
Maxine Filcher
회원 가입일: 01/30/17
1,135 평판
안내서 8개 작성하였습니다
UW Tacoma, Team 1-5, Rose Winter 2017 UW Tacoma, Team 1-5, Rose Winter 2017 회원
UWT-ROSE-W17S1G5
4 회원들
안내서 16개 작성하였습니다
댓글 한 개
I appreciate it
Thedeen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 12
전체 시간: 1,076
