주요 콘텐츠로 건너뛰기
Sony Vaio VPCEG26FX Fan Replacement
필요한 것
  1. Sony Vaio VPCEG26FX Fan Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop so the bottom is facing up with the model number visible.
  2. Sony Vaio VPCEG26FX Fan Replacement: 2 단계, 이미지 1/2 Sony Vaio VPCEG26FX Fan Replacement: 2 단계, 이미지 2/2
    • Slide the lock switch down until you hear a click to unlock the battery.
  3. Sony Vaio VPCEG26FX Fan Replacement: 3 단계, 이미지 1/2 Sony Vaio VPCEG26FX Fan Replacement: 3 단계, 이미지 2/2
    • Slide the release slider up and simultaneously push the battery upwards away from the device until it falls out of place.
  4. Sony Vaio VPCEG26FX Fan Replacement: 4 단계, 이미지 1/2 Sony Vaio VPCEG26FX Fan Replacement: 4 단계, 이미지 2/2
    • Remove the battery from the battery compartment.
  5. Sony Vaio VPCEG26FX Fan Replacement, Back Panel: 5 단계, 이미지 1/1
    • Remove the remaining eleven 7mm screws from back panel using the JIS #0 screwdriver.
  6. Sony Vaio VPCEG26FX Fan Replacement: 6 단계, 이미지 1/2 Sony Vaio VPCEG26FX Fan Replacement: 6 단계, 이미지 2/2
    • Remove the back panel from the device.
  7. Sony Vaio VPCEG26FX Fan Replacement, Fan: 7 단계, 이미지 1/1
    • Remove the three 7mm screws attached to the fan using the JIS #0 screwdriver.
  8. Sony Vaio VPCEG26FX Fan Replacement: 8 단계, 이미지 1/3 Sony Vaio VPCEG26FX Fan Replacement: 8 단계, 이미지 2/3 Sony Vaio VPCEG26FX Fan Replacement: 8 단계, 이미지 3/3
    • Unplug and remove the Fan.
결론
Sara Alfaro
회원 가입일: 03/08/19
531 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S1-G4, Botvin Spring 2019 UMass Dartmouth, Team S1-G4, Botvin Spring 2019 회원
UMASSD-BOTVIN-S19S1G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 8
전체 시간: 426
