주요 콘텐츠로 건너뛰기
Sony Vaio VPCEG37FM Battery Replacement
  1. Sony Vaio VPCEG37FM Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Unlock the battery by sliding the lock upwards.
  2. Sony Vaio VPCEG37FM Battery Replacement: 2 단계, 이미지 1/2 Sony Vaio VPCEG37FM Battery Replacement: 2 단계, 이미지 2/2
    • Slide the release upwards and lift out the battery to remove.
    • Once battery is removed, long press the Power button for 30-60s and discharge any remaining power inside of the computer.
    • Put on the ESD bracelet, making sure the metal circle is touching your skin. Remove the alligator clip from the other end of the bracelet and insert the jack into the ground plug of an active electrical outlet. (the round hole). Do not move forward until you are grounded.
결론
Morgynn Richlark
회원 가입일: 09/25/17
115 평판
안내서 1개 작성함
University of North Texas, Team S3-G4, Thompson Fall 2017 University of North Texas, Team S3-G4, Thompson Fall 2017 회원
UNT-THOMPSON-F17S3G4
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 20
전체 시간: 1,418
