주요 콘텐츠로 건너뛰기
Sony Vaio VPCW21FX Fan Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Sony Vaio VPCW21FX Fan Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure your device is powered off and unplugged to avoid electric shock.
    • Place your device upside down with the bottom panel facing upwards.
    • Orient the device so the battery is away from you as shown
  2. Sony Vaio VPCW21FX Fan Replacement: 2 단계, 이미지 1/2 Sony Vaio VPCW21FX Fan Replacement: 2 단계, 이미지 2/2
    • Unlock the battery by sliding the lock switch to the right.
    • Locate the release latch. Slide the latch to the left to remove the battery from your laptop.
    • Be sure to lift up on the battery while you slide the latch to the left.
  3. Sony Vaio VPCW21FX Fan Replacement: 3 단계, 이미지 1/2 Sony Vaio VPCW21FX Fan Replacement: 3 단계, 이미지 2/2
    • Remove the battery from your laptop.
  4. Sony Vaio VPCW21FX Fan Replacement, Headphone Jack: 4 단계, 이미지 1/2 Sony Vaio VPCW21FX Fan Replacement, Headphone Jack: 4 단계, 이미지 2/2
    • Place the laptop upside down with the bottom panel facing upwards.
    • Locate the screw that holds the small panel covering your laptop's Ram. This panel should be in the dead center of your laptop.
    • Unscrew the screw and remove the panel.
  5. Sony Vaio VPCW21FX Fan Replacement: 5 단계, 이미지 1/1
    • Before you move away from where your RAM is located, be sure to unplug the wire labeled To MB. If you do not unplug this, the back panel you are trying to remove will not come off.
  6. Sony Vaio VPCW21FX Fan Replacement: 6 단계, 이미지 1/3 Sony Vaio VPCW21FX Fan Replacement: 6 단계, 이미지 2/3 Sony Vaio VPCW21FX Fan Replacement: 6 단계, 이미지 3/3
    • Next, locate the panel covering your laptop's hard drive. This panel should be located on the lower right hand side of your laptop.
    • Unscrew the cover on the hard drive.
    • Remove the hard drive cover.
  7. Sony Vaio VPCW21FX Fan Replacement: 7 단계, 이미지 1/3 Sony Vaio VPCW21FX Fan Replacement: 7 단계, 이미지 2/3 Sony Vaio VPCW21FX Fan Replacement: 7 단계, 이미지 3/3
    • Remove screws.
    • Remove screws and remove panel.
  8. Sony Vaio VPCW21FX Fan Replacement: 8 단계, 이미지 1/3 Sony Vaio VPCW21FX Fan Replacement: 8 단계, 이미지 2/3 Sony Vaio VPCW21FX Fan Replacement: 8 단계, 이미지 3/3
    • Remove the hard drive by gently pressing down on it and sliding it to the right.
    • Remember to have a clean work space to place the parts you take off your laptop. It'd be embarrassing to forget to reassemble a part or have a screw or two left over.
  9. Sony Vaio VPCW21FX Fan Replacement: 9 단계, 이미지 1/3 Sony Vaio VPCW21FX Fan Replacement: 9 단계, 이미지 2/3 Sony Vaio VPCW21FX Fan Replacement: 9 단계, 이미지 3/3
    • Remove the screws holding the rest of the outside panel down.
    • Gently lift the panel up to remove it once all the screws have been removed.
  10. Sony Vaio VPCW21FX Fan Replacement: 10 단계, 이미지 1/3 Sony Vaio VPCW21FX Fan Replacement: 10 단계, 이미지 2/3 Sony Vaio VPCW21FX Fan Replacement: 10 단계, 이미지 3/3
    • Once the back panel has been removed, set the rest of your laptop to the side and place the panel you just removed in front of you.
    • Locate the headphone jack, which will be in the top right hand corner of the panel. The headphone jack board is a bright green, you can't miss it.
  11. Sony Vaio VPCW21FX Fan Replacement: 11 단계, 이미지 1/2 Sony Vaio VPCW21FX Fan Replacement: 11 단계, 이미지 2/2
    • Remove the screws holding the headphone jack board down.
  12. Sony Vaio VPCW21FX Fan Replacement: 12 단계, 이미지 1/2 Sony Vaio VPCW21FX Fan Replacement: 12 단계, 이미지 2/2
    • Gently pull the board to remove it.
  13. Sony Vaio VPCW21FX Fan Replacement, Fan: 13 단계, 이미지 1/2 Sony Vaio VPCW21FX Fan Replacement, Fan: 13 단계, 이미지 2/2
    • Locate the fan on the top right hand corner of your laptop.
  14. Sony Vaio VPCW21FX Fan Replacement: 14 단계, 이미지 1/2 Sony Vaio VPCW21FX Fan Replacement: 14 단계, 이미지 2/2
    • Remove screws.
    • Unplug the wires connecting the fan and the motherboard.
  15. Sony Vaio VPCW21FX Fan Replacement: 15 단계, 이미지 1/1
    • Gently pick up the fan to remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Summer
회원 가입일: 10/10/16
250 평판
안내서 2개 작성하였습니다
Sam Houston State, Team 12-6, Blackburne Fall 2016 Sam Houston State, Team 12-6, Blackburne Fall 2016 회원
SHSU-BLACKBURNE-F16S12G6
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
thank you, sir!!!
Robin Watson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 21
전체 시간: 1,293
