주요 콘텐츠로 건너뛰기
Sony Vaio VPCW21FX Hard Drive Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Sony Vaio VPCW21FX Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure your device is powered off and unplugged to avoid electric shock.
    • Place your device upside down with the bottom panel facing upwards.
    • Orient the device so the battery is away from you as shown
  2. Sony Vaio VPCW21FX Hard Drive Replacement: 2 단계, 이미지 1/2 Sony Vaio VPCW21FX Hard Drive Replacement: 2 단계, 이미지 2/2
    • Unlock the battery by sliding the lock switch to the right.
    • Locate the release latch. Slide the latch to the left to remove the battery from your laptop.
    • Be sure to lift up on the battery while you slide the latch to the left.
  3. Sony Vaio VPCW21FX Hard Drive Replacement: 3 단계, 이미지 1/2 Sony Vaio VPCW21FX Hard Drive Replacement: 3 단계, 이미지 2/2
    • Remove the battery from your laptop.
  4. Sony Vaio VPCW21FX Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/3 Sony Vaio VPCW21FX Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2/3 Sony Vaio VPCW21FX Hard Drive Replacement, Hard Drive: 4 단계, 이미지 3/3
    • Remove the two 4.8mm screws that are holding the bottom right panel cover.
    • Remove the Panel cover by lifting it up.
  5. Sony Vaio VPCW21FX Hard Drive Replacement: 5 단계, 이미지 1/2 Sony Vaio VPCW21FX Hard Drive Replacement: 5 단계, 이미지 2/2
    • Remove the two 4.8mm screws that are holding the hard drive down.
  6. Sony Vaio VPCW21FX Hard Drive Replacement: 6 단계, 이미지 1/3 Sony Vaio VPCW21FX Hard Drive Replacement: 6 단계, 이미지 2/3 Sony Vaio VPCW21FX Hard Drive Replacement: 6 단계, 이미지 3/3
    • Grab the black tab that is attached to the hard drive.
    • Slide hard drive to the left to release it from the computer
    • Pull drive up from there and it will come out.
결론
Nicholas Corcoran
회원 가입일: 03/08/17
401 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S2-G5, Isaacson Spring 2017 UMass Dartmouth, Team S2-G5, Isaacson Spring 2017 회원
UMASSD-ISAACSON-S17S2G5
2 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 530
