주요 콘텐츠로 건너뛰기
Sony Vaio VPCW21FX Keyboard Replacement
필요한 것
  1. Sony Vaio VPCW21FX Keyboard Replacement, Battery: 1 단계, 이미지 1/3 Sony Vaio VPCW21FX Keyboard Replacement, Battery: 1 단계, 이미지 2/3 Sony Vaio VPCW21FX Keyboard Replacement, Battery: 1 단계, 이미지 3/3
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio VPCW21FX Keyboard Replacement: 2 단계, 이미지 1/3 Sony Vaio VPCW21FX Keyboard Replacement: 2 단계, 이미지 2/3 Sony Vaio VPCW21FX Keyboard Replacement: 2 단계, 이미지 3/3
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio VPCW21FX Keyboard Replacement, Keyboard: 3 단계, 이미지 1/3 Sony Vaio VPCW21FX Keyboard Replacement, Keyboard: 3 단계, 이미지 2/3 Sony Vaio VPCW21FX Keyboard Replacement, Keyboard: 3 단계, 이미지 3/3
    • Open the Lid of the laptop
    • Then using they pry tool to carefully remove the plastic cover around the keyboard
    • It helps to pry from one of the larger keys as they have more room to fit the tool in
  4. Sony Vaio VPCW21FX Keyboard Replacement: 4 단계, 이미지 1/3 Sony Vaio VPCW21FX Keyboard Replacement: 4 단계, 이미지 2/3 Sony Vaio VPCW21FX Keyboard Replacement: 4 단계, 이미지 3/3
    • Close the lid and flip the laptop over
    • Loosen but do not remove the screw on center panel and remove Panel.
  5. Sony Vaio VPCW21FX Keyboard Replacement: 5 단계, 이미지 1/2 Sony Vaio VPCW21FX Keyboard Replacement: 5 단계, 이미지 2/2
    • Remove the three 5mm screws that are holding in the keyboard.
  6. Sony Vaio VPCW21FX Keyboard Replacement: 6 단계, 이미지 1/3 Sony Vaio VPCW21FX Keyboard Replacement: 6 단계, 이미지 2/3 Sony Vaio VPCW21FX Keyboard Replacement: 6 단계, 이미지 3/3
    • Flip laptop over again and open the lid
    • Lift up the keyboard from the top and lean it toward you to expose the connector on the back
    • Grab the wire from the keyboard close to the connector and pull carefully to the left to disconnect it from the laptop.
결론
Nicholas Corcoran
회원 가입일: 03/08/17
401 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S2-G5, Isaacson Spring 2017 UMass Dartmouth, Team S2-G5, Isaacson Spring 2017 회원
UMASSD-ISAACSON-S17S2G5
2 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 25
전체 시간: 2,220
