주요 콘텐츠로 건너뛰기
Sony Vaio VPCW21FX RAM Replacement
필요한 것
  1. Sony Vaio VPCW21FX RAM Replacement, Battery: 1 단계, 이미지 1/3 Sony Vaio VPCW21FX RAM Replacement, Battery: 1 단계, 이미지 2/3 Sony Vaio VPCW21FX RAM Replacement, Battery: 1 단계, 이미지 3/3
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio VPCW21FX RAM Replacement: 2 단계, 이미지 1/3 Sony Vaio VPCW21FX RAM Replacement: 2 단계, 이미지 2/3 Sony Vaio VPCW21FX RAM Replacement: 2 단계, 이미지 3/3
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio VPCW21FX RAM Replacement, RAM: 3 단계, 이미지 1/3 Sony Vaio VPCW21FX RAM Replacement, RAM: 3 단계, 이미지 2/3 Sony Vaio VPCW21FX RAM Replacement, RAM: 3 단계, 이미지 3/3
    • Loosen but do not remove the screw over RAM cover panel.
    • With the screw loosened but not removed, lift up and remove the panel.
  4. Sony Vaio VPCW21FX RAM Replacement: 4 단계, 이미지 1/3 Sony Vaio VPCW21FX RAM Replacement: 4 단계, 이미지 2/3 Sony Vaio VPCW21FX RAM Replacement: 4 단계, 이미지 3/3
    • Locate the mounting bracket holding the RAM Chips in the computer.
    • Pull silver tabs away from the chip.
    • The chip will pop up, this is normal.
    • Don't touch gold pins on RAM chip.
  5. Sony Vaio VPCW21FX RAM Replacement: 5 단계, 이미지 1/2 Sony Vaio VPCW21FX RAM Replacement: 5 단계, 이미지 2/2
    • Slide RAM chip out by holding the sides of the chip and pull away from the computer.
    • Repeat previous steps for second RAM chip.
결론
Nicholas Corcoran
회원 가입일: 03/08/17
401 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S2-G5, Isaacson Spring 2017 UMass Dartmouth, Team S2-G5, Isaacson Spring 2017 회원
UMASSD-ISAACSON-S17S2G5
2 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 35
전체 시간: 3,307
