주요 콘텐츠로 건너뛰기
Sony WF-1000XM3 Earbud Battery Replacement
필요한 것
  1. Sony WF-1000XM3 Earbud Battery Replacement, Earbud Battery: 1 단계, 이미지 2개 중 1개 Sony WF-1000XM3 Earbud Battery Replacement, Earbud Battery: 1 단계, 이미지 2개 중 2개
    • Use a spudger to gently pry open the back plate of the earbud.
  2. Sony WF-1000XM3 Earbud Battery Replacement: 2 단계, 이미지 3개 중 1개 Sony WF-1000XM3 Earbud Battery Replacement: 2 단계, 이미지 3개 중 2개 Sony WF-1000XM3 Earbud Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Use a Phillips #000 screwdriver to remove the two 4 mm screws securing the internal components.
    • Both sides of the earbuds are attached with a ribbon cable. Separate the two halves carefully to prevent tearing the cable.
  3. Sony WF-1000XM3 Earbud Battery Replacement: 3 단계, 이미지 2개 중 1개 Sony WF-1000XM3 Earbud Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Use a spudger to carefully remove the battery from the earbud's circuit board.
    • When replacing the battery, make sure to keep the same orientation as the old battery and reconnect the battery to the circuit board.
  4. Sony WF-1000XM3 Earbud Battery Replacement: 4 단계, 이미지 3개 중 1개 Sony WF-1000XM3 Earbud Battery Replacement: 4 단계, 이미지 3개 중 2개 Sony WF-1000XM3 Earbud Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Use a spudger to pry the battery and the metal negative contact from the earbud.
    • The battery and the negative contact are secured with double-sided tape, so it may take some force to remove them.
  5. Sony WF-1000XM3 Earbud Battery Replacement: 5 단계, 이미지 3개 중 1개 Sony WF-1000XM3 Earbud Battery Replacement: 5 단계, 이미지 3개 중 2개 Sony WF-1000XM3 Earbud Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the metal negative terminal from the battery.
    • Attach it to the new battery, either with double-sided tape or by placing the new battery and the terminal back into the earbud in the same position they were before.
결론
To reassemble your device, follow these instructions in reverse order. Double-check your work to ensure everything is properly reassembled. Test the earbuds to confirm that the new battery is functioning correctly. If the earbud does not power on, recheck the connections and ensure the battery is connected correctly. Take your e-waste to an R2 or e-Stewards certified recycler.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
WyattC
회원 가입일: 10/24/24
470 평판
안내서 4개를 작성함
UMass Dartmouth, Team 3-6, Santin Fall 2024 UMass Dartmouth, Team 3-6, Santin Fall 2024 회원
UMASSD-SANTIN-F24S3G6
3 회원들
안내서 9개를 작성함
1가이드 댓글
What battery does it take?
Aman Singh - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 36
지난 30일: 260
전체 시간: 2,588
