소개
Follow this guide to replace the microphone array on the Sony WH-1000XM4 wireless headphones.
Ensure the headphones are powered off and discharged.
As a precaution utilize the anti-static wrist strap to avoid damaging any of the electronic components.
필요한 것
Use your thumb to depress the LEFT ear pad near the long outer edge, creating a gap between the cushion and the frame.
Insert the flat end of a spudger into the gap you've created, between the edge of the cushion and the frame.
Pivot the spudger down to unclip the long edge of the ear pad.
다른 한 분이 해당 안내서를 완성하였습니다.
