주요 콘텐츠로 건너뛰기
Sony WH-1000XM4 Motherboard Replacement
필요한 것
  1. Sony WH-1000XM4 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Before beginning any repairs, press and hold the power button on the left ear cup for about 2 seconds until the blue light turns off.
    • Place your headphones onto a work surface, ear pads facing up.
  2. Sony WH-1000XM4 Motherboard Replacement: 2 단계, 이미지 1/1
    • Use your thumb to depress the LEFT ear pad near the long outer edge, creating a gap between the cushion and the frame.
    • Pivot the spudger down to unclip the long edge of the ear pad.
    • Repeat around the perimeter of the ear pad until it is loose.
    • When the first clip disconnects, you'll hear an audible clicking sound.
    • This may take a considerable amount of force. If the cushion won't click out of place, move your spudger to different points along the long edge.
  3. Sony WH-1000XM4 Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove the left ear pad.
  4. Sony WH-1000XM4 Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove the foam liner from the left ear cup's speaker.
  5. Sony WH-1000XM4 Motherboard Replacement: 5 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the four 8.4 mm screws securing the left ear cup cover.
  6. Sony WH-1000XM4 Motherboard Replacement: 6 단계, 이미지 1/1
    • Flip the headphones over, ear cups facing down.
    • Use your fingers to lift up and flip over the left ear cup cover.
    • Don't try to completely remove the cover just yet—it's still attached with many cables.
  7. Sony WH-1000XM4 Motherboard Replacement: 7 단계, 이미지 1/1
    • Unscrew the 4 screws in the corners of the motherboard to loosen it from the left ear cup assembly.
  8. Sony WH-1000XM4 Motherboard Replacement: 8 단계, 이미지 1/1
    • Carefully remove the cable ribbon from the bottom of the motherboard.
  9. Sony WH-1000XM4 Motherboard Replacement: 9 단계, 이미지 1/1
    • Carefully remove the multipin connector (multiple colorful wires) from the side of the motherboard.
  10. Sony WH-1000XM4 Motherboard Replacement: 10 단계, 이미지 1/1
    • Carefully lift the motherboard out from the ear cup to access the other cable ribbons and connectors.
  11. Sony WH-1000XM4 Motherboard Replacement: 11 단계, 이미지 1/1
    • Remove wires from the side or bottom of the motherboard that are attached by pin connectors.
  12. Sony WH-1000XM4 Motherboard Replacement: 12 단계, 이미지 1/1
    • Desolder the remaining wires that are attached to the motherboard.
    • Repeat steps in reverse order to reassemble the headphones after seating the new motherboard.
    • Reference the Service Manual on the Sony WH-1000XM4 main page on the IFixIt website to verify correct wire connections.
결론
Spencer Decker
회원 가입일: 11/09/23
499 평판
안내서 3개 작성하였습니다
IUPUI, Team 2-1, Harley Fall 2023 IUPUI, Team 2-1, Harley Fall 2023 회원
IUPUI-HARLEY-F23S2G1
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 66
30일 전: 275
전체 시간: 1,957
