주요 콘텐츠로 건너뛰기
Sony WH-1000XM4 Swivel Replacement
필요한 것
  1. Sony WH-1000XM4 Swivel Replacement, Swivel: 1 단계, 이미지 1/3 Sony WH-1000XM4 Swivel Replacement, Swivel: 1 단계, 이미지 2/3 Sony WH-1000XM4 Swivel Replacement, Swivel: 1 단계, 이미지 3/3
    • Using an opening tool, pry off the right ear muff and remove the underlying foam.
  2. Sony WH-1000XM4 Swivel Replacement: 2 단계, 이미지 1/2 Sony WH-1000XM4 Swivel Replacement: 2 단계, 이미지 2/2
    • Using an opening tool, pry off the left ear muff and remove the underlying foam.
  3. Sony WH-1000XM4 Swivel Replacement: 3 단계, 이미지 1/2 Sony WH-1000XM4 Swivel Replacement: 3 단계, 이미지 2/2
    • Remove the four silver screws on both sides of the headphones using a Phillips #000 screwdriver.
  4. Sony WH-1000XM4 Swivel Replacement: 4 단계, 이미지 1/3 Sony WH-1000XM4 Swivel Replacement: 4 단계, 이미지 2/3 Sony WH-1000XM4 Swivel Replacement: 4 단계, 이미지 3/3
    • Flip the headphones.
    • Lift the back of both sides of the headphones.
  5. Sony WH-1000XM4 Swivel Replacement: 5 단계, 이미지 1/2 Sony WH-1000XM4 Swivel Replacement: 5 단계, 이미지 2/2
    • Detach the ribbon cable connecting the backplate to the right ear.
  6. Sony WH-1000XM4 Swivel Replacement: 6 단계, 이미지 1/2 Sony WH-1000XM4 Swivel Replacement: 6 단계, 이미지 2/2
    • Detach the yellow thermal sensor ribbon cable from the motherboard.
  7. Sony WH-1000XM4 Swivel Replacement: 7 단계, 이미지 1/2 Sony WH-1000XM4 Swivel Replacement: 7 단계, 이미지 2/2
    • Detach the data/pwr connector from the motherboard using an opening tool.
  8. Sony WH-1000XM4 Swivel Replacement: 8 단계, 이미지 1/1
    • Remove the two screws from the motherboard using a Phillips #000 screwdriver.
  9. Sony WH-1000XM4 Swivel Replacement: 9 단계, 이미지 1/2 Sony WH-1000XM4 Swivel Replacement: 9 단계, 이미지 2/2
    • Disconnect the white ribbon cable.
  10. Sony WH-1000XM4 Swivel Replacement: 10 단계, 이미지 1/3 Sony WH-1000XM4 Swivel Replacement: 10 단계, 이미지 2/3 Sony WH-1000XM4 Swivel Replacement: 10 단계, 이미지 3/3
    • Move the data/pwr cable from the inside of the board to the outside.
  11. Sony WH-1000XM4 Swivel Replacement: 11 단계, 이미지 1/2 Sony WH-1000XM4 Swivel Replacement: 11 단계, 이미지 2/2
    • On the left ear, detach the ribbon cable attaching the nfc from the back panel to the motherboard.
  12. Sony WH-1000XM4 Swivel Replacement: 12 단계, 이미지 1/1
    • Remove the data/ pwr connector from board.
  13. Sony WH-1000XM4 Swivel Replacement: 13 단계, 이미지 1/2 Sony WH-1000XM4 Swivel Replacement: 13 단계, 이미지 2/2
    • On the right ear, rotate the motherboard and remove the two screws from the hinge using a Phillips #000 screwdriver.
    • On the left ear, remove the two screws from the hinge using a Phillips #000 screwdriver.
  14. Sony WH-1000XM4 Swivel Replacement: 14 단계, 이미지 1/2 Sony WH-1000XM4 Swivel Replacement: 14 단계, 이미지 2/2
    • On the right ear, lift the hinge and push it out.
  15. Sony WH-1000XM4 Swivel Replacement: 15 단계, 이미지 1/2 Sony WH-1000XM4 Swivel Replacement: 15 단계, 이미지 2/2
    • On the left ear, lift the hinge and push it out.
  16. Sony WH-1000XM4 Swivel Replacement: 16 단계, 이미지 1/2 Sony WH-1000XM4 Swivel Replacement: 16 단계, 이미지 2/2
    • Remove the black hinge piece from the data/ pwr cable.
  17. Sony WH-1000XM4 Swivel Replacement: 17 단계, 이미지 1/2 Sony WH-1000XM4 Swivel Replacement: 17 단계, 이미지 2/2
    • Using a screwdriver, remove the rubber band.
  18. Sony WH-1000XM4 Swivel Replacement: 18 단계, 이미지 1/2 Sony WH-1000XM4 Swivel Replacement: 18 단계, 이미지 2/2
    • Use an opening tool to remove the cover.
  19. Sony WH-1000XM4 Swivel Replacement: 19 단계, 이미지 1/1
    • Lift up the data/ pwr cable.
  20. Sony WH-1000XM4 Swivel Replacement: 20 단계, 이미지 1/1
    • Remove the two screws from the swivel using a Phillips #000 screwdriver.
  21. Sony WH-1000XM4 Swivel Replacement: 21 단계, 이미지 1/2 Sony WH-1000XM4 Swivel Replacement: 21 단계, 이미지 2/2
    • Push out the metal bit from the swivel piece using a spudger.
    • Pull out the metal bit.
  22. Sony WH-1000XM4 Swivel Replacement: 22 단계, 이미지 1/2 Sony WH-1000XM4 Swivel Replacement: 22 단계, 이미지 2/2
    • Remove the old swivel.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Jian Mejia
회원 가입일: 08/23/23
490 평판
안내서 1개 작성함
CSU Los Angeles, Team 4-13, Kershman Fall 2023 CSU Los Angeles, Team 4-13, Kershman Fall 2023 회원
CSULA-KERSHMAN-F23S4G13
1 회원
안내서 4개 작성하였습니다
댓글 3개
really helpful, thank you! my swivel snapped. I started from Step 18 and removed the cover halfway. re-inserted the swivel then locked the metal bit back. i don't have the replacement piece and it will snap again if twisted too far, but this works for now. thanks!!
jianne - 답글
Here are a few suggestions:
1) Do a google search for 'sony headphones wh1000xm4 replacement plastics'
2) SONY Replacement Parts Website (what they offer) I found at this site.
3) Joe's SONY WH-1000XM4 Repair Parts I found at this site.
- The individual part you needed is offered along with a replacement metal clip.⏎
4) Check eBay - Currently (2/9/24) I see the part you need along with the two piece that attaches from the swivel joint to the speaker for about $11.99 USD
sonnyhung - 답글
I hear a creaking sound on my left earcup and have tried everything to remove it (tape, lube, opening the sides up) but to no avail. Should I do this guide and check if the creaking is in the hinge part? Thanks.
EJ Vinuya (EJ) - 답글
댓글 쓰기
조회 통계:
24 시간 전: 30
7일 전: 184
30일 전: 845
전체 시간: 4,800
