주요 콘텐츠로 건너뛰기
Sony WH-1000XM5 Earcup swivel Re-attachment - incomplete
필요한 것
    • Using the spugger pull the earpad inward, and pry the ear pad up and away from the earcup
  1. Sony WH-1000XM5 Earcup swivel Re-attachment - incomplete, Separate back of earcup: 2 단계, 이미지 1/1
    • We separate the back of the ear cup to get better acsess to the arm later
    • Remove the non glued down foam, and the 8 marked screws
  2. Sony WH-1000XM5 Earcup swivel Re-attachment - incomplete, Remove headband screw: 3 단계, 이미지 1/1
    • this screw is easyer to acsess without the back of the headphone cup
  3. Sony WH-1000XM5 Earcup swivel Re-attachment - incomplete, Remove earcup arm screw and plate: 4 단계, 이미지 1/1
    • Rushed for time, i didnt remember to take a photo of this part, please forgive me
    • there is a screwed and plate covering the attachment hardware that has come lose its location is indicated here:
    • We can use the access back here to hold onto the silver mounting screw and make sure we can screw the arm back together
  4. Sony WH-1000XM5 Earcup swivel Re-attachment - incomplete, remove wire clamp mold, and re-attach arm: 5 단계, 이미지 1/1
    • pull out this adjustable arm piece out of the headband
    • Unscrew the wire free from the adjustable arm piece, letting the arm spin freely around the wire.
    • screw the adjustable arm piece back on-to the earcup arm, in my case there was some resistance from a lip on the screw that prevented it becoming unscrewed in the first place. i was able to gently push past it multiple times till it was screwed on snugly
  5. Sony WH-1000XM5 Earcup swivel Re-attachment - incomplete, Reasemble: 6 단계, 이미지 1/1
    • go backwards though the steps to re-assemble
    • as always, i added a little Easter egg to my free repairs.
결론
Sorry there are not more detailed photos, I was rushed to fix this and making it up as I go along.
If i can fix it, so can you <3
Conor Bone
회원 가입일: 11/04/20
324 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 14
7일 전: 82
30일 전: 357
전체 시간: 599
