주요 콘텐츠로 건너뛰기
Sony Walkman NWZ-E438 Battery Replacement
필요한 것
  1. Sony Walkman NWZ-E438 Battery Replacement, Disassembling Sony Walkman NWZ-E438: 1 단계, 이미지 1/1
    • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
    • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
  2. Sony Walkman NWZ-E438 Battery Replacement: 2 단계, 이미지 1/1
    • Use a small prying tool to carefully pry open the back of the device.
  3. Sony Walkman NWZ-E438 Battery Replacement, Battery: 3 단계, 이미지 1/1
    • Peel back the black tape from the device to the battery from the side of the device.
  4. Sony Walkman NWZ-E438 Battery Replacement: 4 단계, 이미지 1/1
    • Using a small, plastic prying tool slowly lift the battery around all edges.
    • Careful of wires connecting the battery to the device.
  5. Sony Walkman NWZ-E438 Battery Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Remove the yellow film covering the circuit board with pointed precision tweezers.
  6. Sony Walkman NWZ-E438 Battery Replacement: 6 단계, 이미지 1/2 Sony Walkman NWZ-E438 Battery Replacement: 6 단계, 이미지 2/2
    • Using tweezers, unplug the gold band connecting the device and circuit board.
  7. Sony Walkman NWZ-E438 Battery Replacement: 7 단계, 이미지 1/2 Sony Walkman NWZ-E438 Battery Replacement: 7 단계, 이미지 2/2
    • Using pointed precision tweezers, unplug the wires connecting the battery and chip from the chip.
  8. Sony Walkman NWZ-E438 Battery Replacement: 8 단계, 이미지 1/1
    • Remove battery.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Cheryl Zinn
회원 가입일: 10/08/15
525 평판
안내서 5개 작성하였습니다
댓글 한 개
Do you have a link to purchase a replacement battery? Thanks!
jacob goff - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 53
전체 시간: 6,615
